Brain Teaser #91: Brain Thumper #5: How Long is the Average Break?
  • Context: Graduate
  • Thread starter Thread starter davilla
    Brain
The discussion revolves around a brain teaser involving a bus transit system in a small city, focusing on the average break time for bus drivers under specific operational conditions. Participants explore various interpretations of the problem, calculations of break times, and the implications of different assumptions regarding the number of operators and routes.
  • One participant claims the average break length is 114/11 minutes.
  • Another participant questions the logic behind this calculation and suggests that the number of operators should be changed from 60 to 62 for clarity.
  • A different calculation proposes that with 62 drivers, there are 3 breaks every 285 driving minutes, leading to an average break time of 25/3 minutes.
  • One participant mentions arriving at an average break of 8:20 using a different method and suggests an arithmetic mistake in earlier calculations.
  • Another participant notes that the intended average headway was originally 10-15 minutes but acknowledges a mistake in summing due to bidirectional routes.
  • There is a discussion about the terminology used in the problem, specifically regarding the number of routes and the ambiguity of the term "route" in the context of graph theory.
  • Clarifications are made regarding the counting of routes, with one participant stating that both directions of the routes were considered, leading to confusion about the total number of routes.
Participants express differing views on the calculations of average break times, with no consensus reached on the correct average. There is also disagreement regarding the interpretation of the problem's terminology and the number of routes involved.
Participants highlight potential ambiguities in the problem's description, particularly regarding the definition of "route" and the counting of routes in relation to the graph theory context. There are also unresolved assumptions about the operational conditions affecting the calculations.
This discussion may be of interest to those engaged in mathematical problem-solving, particularly in the context of operational logistics and scheduling in transit systems.
davilla
Brain Thumper #5
Five transit centers are evenly spaced near the perimeter of a small city. Any two transit centers are connected by exactly one route. Additionally, from each transit center there is one route that extends into the suburbs in the shape of a large colorful lollipop. The five routes passing through the downtown area take 50 minutes to travel for all-stops buses and 40 minutes for express buses that stop only at transfer points. Buses on the remaining routes serve all stops. On perimeter routes they take half an hour to travel between transit centers, and on suburb routes 45 minutes to complete the loop and return to the same transit center.
Buses that enter a transit center are dynamically rerouted using a simple pattern. Each transit center employs the following mechanism independently. Regarless of the originating route, the first two buses are designated as express buses and the next two buses serve all stops in the heart of the city. The next three buses proceed in a clockwise manner among the three remaining routes, and then we start over. The pattern repeats in this rotation, sending out each bus as soon as it arrives.
If a bus driver comes in along a route of 40 minutes or less, he or she must continue operating the bus on whatever route it's reassigned to. Otherwise, the driver gets a break while a relief operator takes over the vehicle. The driver on break will serve as the relief for the next bus coming in on a route of 45 minutes or more. It's like a game of musical chairs, with buses always in use and hopefully only one person driving.
There are 62 operators on duty and as many buses in operation as necessary to keep them busy. How long is the average break?
Mathematics news on Phys.org
114/11 minutes is the average break length.
There are 60 operators on duty and as many buses in operation as necessary to keep them busy. How long is the average break?
I think I know how you arrived at this number and the logic doesn't seem correct. However, I made a mistake myself when first formulating the problem, so if you would like to explain how you arrived at the answer I might be proved wrong. Please forgive me for changing the number of operators from 60 to 62. This should make the numbers come out cleaner.
With 62 drivers:
62 drivers means that there are 62 driver minutes per minute
Despite the complicated system for scheduling busses, the conditions imply that there will be one driver at each station at all times.
That means that there are 5 breaking driver minutes per minute
so there are 57 driving driver minutes per minute.
Since there are three breaks per 285 minutes of driving (Consider batches of seven busses sent out from each station) that means that there are 3 breaks / 285 driving minutes * 57 driving minutes / minute = 3/5 breaks per minute.
So there are three new breaks every five minutes, and there are 25 minutes of break time every five minutes, so the average break time is 25/3 minutes.
I expect that you wanted the average break time to come out to three minutes.
Yes! Using a different method I also got an average break of 8:20.
Using your method for the case of 60 operators I came up with 95/11 or a little closer to 9 minutes, so I think you may have made an arithmetic mistake earlier.
No, I originally wanted the average headway to be 10-15 minutes, but in summing I neglected to double the time for bidirectional routes.
By the sound of it, I prefer my approach.
P.S. Redid the work, and got 95/11 also.
BTW:
It turns out not to be important, but your description of the routes is a bit confusing. I assume that the graph should be isomorphic to K5 with tails, but you mention 'five routes passing through downtown' when there should be ten. You also have 'connected by exactly one route' but it's ambiguous whether route means path or edge in the sense of graph theory.
If you re-use this, you might consider replacing "route" with "direct route", and replacing five with ten, or omitting it entirely.
NateTG said:
You mention 'five routes passing through downtown' when there should be ten.
I'm not sure how you're counting ten. The five perimeter routes are crosstown since the downtown area is the center of the city.
The express buses are a variation of the regular buses. It's really the same numbered route, just a different type of service.
NateTG said:
It's ambiguous whether route means path or edge in the sense of graph theory.
By "route" I meant a bus route, which doesn't fall under either definition. In this case each route is an edge, but in general it is a named path.
I can see how this could be confusing. Thanks for putting up with the strange jargon.
I was counting both directions of the routes - must have been a brain fart (=. I suppose there could be five to ten routes really.
11K
9K
  • · Replies 65 ·
13K
