Approximating the "Tail" of a Series
  • Thread starter Thread starter workerant
    Series
The discussion revolves around estimating the tail of the series \(\Sigma (from n=6 to infinity) (4-sin n)/(n^2+1)\) using improper integrals or geometric series. Participants are exploring methods to approximate this series and are considering the implications of the sine function's behavior in their calculations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to use an improper integral to estimate the tail but expresses difficulty in integrating the given function. They suggest considering a simpler series for comparison.
  • Another participant proposes using the improper integral of \(\frac{4}{n^2+1}\) instead, arguing that the sine function's oscillation may reduce the overall error in the approximation.
  • Questions arise regarding the calculation of error in the approximation, particularly how the maximum error is determined and the significance of the sine function's behavior.
The discussion is active, with participants offering different perspectives on the choice of improper integral and the estimation of error. There is a focus on understanding the implications of the sine function in the context of the series, and some guidance has been provided regarding the use of integrals for approximation.
Participants are working under the constraints of homework guidelines, which may limit the methods they can use. There is an ongoing exploration of assumptions related to the behavior of the sine function and its impact on the series approximation.
workerant
[SOLVED] Approximating the "Tail" of a Series
I need to estimate the tail, which is
[tex]\Sigma[/tex] (from n=6 to infinity) (4-sin n)/(n^2+1)
It says to do this with an appropriate improper integral or geometric series.
I don't see a geometric series helping here, so I would use an improper integral. It is too difficult to integrate (4-sin n)/(n^2+1) (if it's even possible), so I'm stuck here. If this can be integrated, please show me the way. I was thinking perhaps do an improper integral for series of 5/n^2 instead since that is always larger (i.e. if you write 4+/- 1)/(n^2+1) instead. Would this be appropriate?
Well yes but I would rather do the improper integral for [tex]\frac{4}{n^2+1}[/tex] because the sine will keep alternating between positive and negative, roughly canceling out each others effects, and also why neglect the +1 in the denominator if we don't have to? Integrating is simple now. We can see that when taking the improper integral, the absolute maximum error extracting the sine is about 0.165, since the sine function has a upper bound of 1, so the maximum error would be [tex]\int^{\infty}_6 \frac{1}{x^2+1} dx[/tex] which is about 0.165. In reality it is much less sine the sine alternates between positive and negative, its less than 0.03.
However, if we were to ignore the +1 in the denominator as well, we would get [tex]4\sum_{n=6}^{\infty} \frac{1}{n^2}[/tex] which is simple if you know [tex]\sum_{n=1}^{\infty} \frac{1}{n^2} = \frac{\pi^2}{6}[/tex]. This method gets you about 0.725..
Thanks!
how exactly do you calculate this error? I understand everythign else such as choice of improper integral, but I don't get where your getting the numbers for the error, is it strictly the value of the improper integral?
  • · Replies 16 ·
  • · Replies 16 ·
