Weight of mass on surface > center of Earth
The discussion centers around the weight of a mass at the surface of the Earth compared to its weight at the center or deep underground. Participants explore concepts from gravitational theory, including Newtonian gravity and General Relativity (GR), and question the implications of these theories on the experience of weight and gravity.
  • One participant questions whether it has been experimentally confirmed that a mass weighs more on the surface of the Earth than at its center, expressing skepticism about the implications of GR.
  • Another participant explains the gravitational force equation and suggests that the gravitational force decreases as one moves towards the center of the Earth, ultimately reaching zero at the center.
  • Some participants relate the concept of gravity to the curvature of space, suggesting that greater curvature at the surface results in greater gravitational force.
  • A participant argues that at the center of a uniform spherical mass, one would feel no gravity due to equal gravitational pulls in all directions, while also expressing confusion about the logic of space curvature.
  • Another participant challenges the assertion that curvature of space is zero at the center, using black holes and the Sun as counterexamples, and argues that being in curved space does not equate to feeling gravity.
  • There is a discussion about the nature of gravitational force, with one participant stating that gravity is not felt directly but rather through normal forces, while another questions this perspective using the example of satellites.
Participants express differing views on the relationship between gravity and space curvature, with no consensus reached on the implications of GR versus Newtonian gravity. The discussion remains unresolved regarding the nature of gravity at the center of the Earth and the validity of various theoretical perspectives.
Some claims rely on assumptions about uniformity and the nature of gravitational fields, while others depend on interpretations of GR and Newtonian physics. The discussion includes unresolved mathematical and conceptual challenges related to gravity and curvature.
tdunc
Logic tells us that a mass on the surface of the Earth weighs more than at the center(or very deep underground). My question is has this been confirmed by experiment? Wouldn't it be truly bizarre if the mass weighed the same?
In any case, I can explain why mass would weigh less according to my ether theory (I think), however I'd like to hear why it would weigh less according to GR (fabric of space), of which I have no answer. I mean we are talking about gravity. Quite frankly GR makes no sense to me period I'll say that right now for the record.
Gravitational force is given by GMm/r2 where G is the "universal gravitational constant", M is the mass of the earth, m is the mass of the object, and r is the distance from the center of the earth. It is pretty easy to show that, because of the "1/r2", that the total mass from a sphere outside that radius is 0: opposite parts cancel. So the "net" force is only due to the mass between the object and the center of the earth. Assuming a uniform Earth (reasonably accurate), the mass "below" the object is 4/3 times density times r3 so we have
Gm(4/3 density r3)/r2= (4/3) Gm density r. That clearly decreases as r decreases and is 0 exactly at the center of the earth.
No one has ever measured anything at the center of the Earth but there have been experiments on object a couple of miles down which support the calculation.
" Quite frankly GR makes no sense to me period I'll say that right now for the record."
In other words "I don't understand it, therefore it is wrong."
Relating that to GR, we can say that the curvature of space is greater at the surface.
Upon further thought
Assume for the moment that the Earth is a perfect sphere with uniform matter. You would feel no gravity at the very center. The same principle can be applied regardless of the circumference of sphere, so you would feel no gravity at the center of the Sun also. This is explained perfectly by GR believe it or not! There is no curvature of space at the center! The center of a uniform spherical mass in emtpy space lies exactly on the surface or horizen of that space!
Against all my better judgement that a bending of space is illogical, it works in this example! And not only does it work, I cannot give a proper explanation of this fact according to my model!
So now if anyone cares to comment, I would like to hear your explanation of such according to your alternate theory of gravity.
Actually I don't know that that statement is accurate. How can we say that the curvature of space is zero at the center? A black hole would not agree with that too well for one. Nor would even a significant mass such as our Sun.
So if no curvature of space equals no gravity felt, then you must conclude that any curvature of space equals gravity felt. Yet that is not the case if the space at center of the Sun for example is curved.
Does that make sense?
The only conclusion you can reach is that at the center you are being pulled equally in all directions, therefore no gravity felt even though you are lying on curved space. With that understanding, we still don't prove a curvature of space is the cause of gravity or even that a curvature exsists.
Who's logic? It seems to me that you're referring to Newton's theory; HallsofIvy's response is within this framework. While differences between GR and Newtonian theories of gravity are observable here on the surface of the Earth, they're pretty small.
IIRC, quite a number of pretty sensitive measurements of gravity were taken a few years ago, when there was a lot of interest in possible deviations from the inverse square relationship. These included measurements down deep mines. No deviations from inverse square found (to the limits of experimental error).
The spacetime geometry for the interior of the Earth does not match that of a black hole. No curvature of space also is not equivalent to no gravity felt. Actually, one never feels the force of gravity. You feel the normal force of the floor up on your feet. And your definition of proof is useless. The spacetime geometry for the interior of the Earth is given by the line element
[tex]ds^{2} = (1 + \frac{GM_{earth}r^{2}}{R^{3}c^{2}} - \frac{3GM_{earth}}{Rc^{2}})dct^{2} - \frac{dr^{2}}{1 - \frac{2GM_{earth}r^{2}}{R^{3}c^{2}}} - r^{2}d\theta ^{2} - r^{2}sin^{2}\theta d\phi ^{2}[/tex]
The r-r spatial componant of the metric does reduce to the value of spherical coordinates in an otherwise flat spacetime at r = 0, but the time component does not. Even so the affine connections do vanish at r = 0 meaning that no gravitational acceleration is observed to occur there.
"The spacetime geometry for the interior of the Earth does not match that of a black hole."
I don't immediatly know what your trying to get at, if you want to elaborate and make a point I'd be willing to listen.
"No curvature of space also is not equivalent to no gravity felt."
Would you like to give an example?
"Actually, one never feels the force of gravity. You feel the normal force of the floor up on your feet."
That statement reads as if it came straight out of a textbook and in no relation or thought to the given concepts we are discussing. I would just rather not comment on that. Actually, take a satellite for example, are you telling me that it does not feel the force of gravity?
I made a point.
I did.
It isn't my fault that you missed the point.
Then why did you?
Yes.
  • · Replies 51 ·
  • · Replies 21 ·
  • · Replies 202 ·
15K
  • · Replies 24 ·
