The discussion revolves around the interaction of gases with applied electromagnetic (E/M) fields and whether such interactions can lead to changes in gas volume. Participants explore theoretical and experimental aspects, including the potential for sound production through these interactions.
- Exploratory, Technical explanation, Conceptual clarification, Debate/contested
- One participant questions if any gases change volume in response to E/M field changes, excluding thermal effects.
- Another participant mentions that O2 and other gases can respond to magnetic and electric fields, referencing experiments where dielectrics are drawn into electric fields.
- A participant expresses curiosity about the mechanism behind O2's interaction with E/M fields, considering possibilities like electrostatic repulsion.
- Suggestions are made to explore "electrostatic speakers" as a means of interacting with air through E/M fields, noting that significant field strengths may be required.
- A participant humorously suggests that clapping hands is a form of direct interaction with air.
Participants present various viewpoints on the interaction of gases with E/M fields, but no consensus is reached regarding specific mechanisms or the feasibility of volume changes in gases.
The discussion does not clarify the assumptions regarding the types of gases or the specific conditions under which these interactions might occur. The dependence on definitions of "direct interaction" and the required field strengths for practical applications remain unresolved.
