Max. Height Insect Can Crawl in a Bowl: u & r
The maximum height an insect can crawl in a bowl, given the coefficient of friction (u) and the radius (r) of the bowl, is determined by the formula h = r [1 - 1/root(1 + u^2)]. This conclusion is derived from analyzing the forces acting on the insect as it climbs an inclined surface of a hemispherical bowl. The relevant equations include F = uR, tan(theta) = u, and the net force equation mg(sin(theta) + u cos(theta)). The correct answer to the problem is option b.
  • Understanding of basic physics concepts such as friction and forces.
  • Familiarity with trigonometric functions and their applications in physics.
  • Knowledge of calculus, specifically derivatives and their geometric interpretations.
  • Ability to analyze geometric shapes, particularly hemispheres and their properties.
  • Study the principles of static and kinetic friction in physics.
  • Learn about the application of trigonometry in solving physics problems.
  • Explore calculus applications in physics, focusing on derivatives and their physical meanings.
  • Investigate the geometry of spheres and hemispheres for better visualization of problems.
Students studying physics, particularly those focusing on mechanics, as well as educators looking for practical examples of friction and force analysis in real-world scenarios.
Mr Virtual
If the coefficient of friction between an insect and bowl surface is u (mu) and the radius of bowl is r, what is the max height upto which the insect can crawl in the bowl?
a) r/root(1 + u2)
b) r [ 1 - 1/root(1 + u2)]
c) r [root(1 + u2)]
d)r [ root(1 + u2) -1 ]
Correct Answer: b
F=uR
tan theta = u
On a non-horizontal plane,
F=mg sin theta
R=mg cos theta
therefore, net f=mg(sin theta + u cos theta)
Can't get the gist of how to approach this question.
With problems like this, first thing you do is go about making a diagram. For all the purposes of this question, we can take the bowl to be a hemisphere. Let's assume that there is a single meridian line of the sphere that the insect travels across. Let's start by taking the cross section of such a line:
http://img267.imageshack.us/img267/5157/insecthelpqi1.jpg
Here, I've assumed a right-handed co-ordinate system, with the circle:
[tex] x^2 + y^2 = r^2[/tex]
Let the insect be at an arbitrary point on the circle (x, y). Now, a very small part of the circle can be taken to be as an inclined plane. The angle it makes can be found out using the angle the tangent on that point makes with the x-axis. It is given by:
[tex] \frac{dy}{dx} = \tan{(\theta)} = -\frac{x}{y}[/tex]
Once, you've done that, you can easily find out the angles, [itex]\sin(\theta)[/itex] and [itex]\cos(\theta)[/itex], using Pythagoras theorem wherever necessary. And hence, you can find the angle of the inclination as a function of the co-ordinates (x, y). But, you need it in the terms of height. With a little algebra and geometry, you can find the co-ordinates as:
[tex] (x, y) \equiv (\sqrt{2hr - h^2}, r - h)[/tex]
And hence, the inclination is given by:
[tex] \frac{dy}{dx} = \tan{(\theta)} = -\frac{x}{y} = \frac{\sqrt{2hr - h^2}}{h - r}[/tex]
Now, you have the force components in terms of the height climbed by the insect. Now, you need to find 'h' such that, the frictional force (caused by the normal force mg cos(θ)) becomes equal to the restraining force [mg sin(θ)] and beyond which it is smaller.
I think you can do the problem now.
  • · Replies 24 ·
11K
