How Do You Calculate Accelerations and Distance in Gyroscope Dynamics?
The discussion focuses on calculating the tangential and radial accelerations, as well as the distance traveled by a point on the rim of a gyroscope flywheel with a radius of 3.33 cm, which accelerates from rest at 13.4 rad/s² to an angular speed of 2760 rev/min. The tangential acceleration can be determined using the formula \( a_t = r \cdot \alpha \), where \( r \) is the radius and \( \alpha \) is the angular acceleration. The radial acceleration at full speed is calculated using \( a_r = \frac{v^2}{r} \), where \( v \) is the linear velocity derived from the angular speed. The distance traveled during the spin-up can be calculated using the kinematic equations for rotational motion.
  • Understanding of angular acceleration and its relation to tangential acceleration
  • Familiarity with the conversion between angular speed in rev/min and linear velocity
  • Knowledge of kinematic equations for rotational motion
  • Basic proficiency in physics, specifically dynamics
  • Calculate tangential acceleration using \( a_t = r \cdot \alpha \)
  • Determine radial acceleration at full speed with \( a_r = \frac{v^2}{r} \)
  • Explore kinematic equations for rotational motion to find distance traveled
  • Convert angular speed from rev/min to rad/s for accurate calculations
Physics students, mechanical engineers, and anyone involved in dynamics and rotational motion calculations will benefit from this discussion.
rytagi17
A gyroscope flywheel of radius 3.33 cm is accelerated from rest at 13.4 rad/s2 until its angular speed is 2760 rev/min.
(a) What is the tangential acceleration of a point on the rim of the flywheel during this spin-up process?
m/s2
(b) What is the radial acceleration of this point when the flywheel is spinning at full speed?
m/s2
(c) Through what distance does a point on the rim move during the spin-up?
m
i've been trying to answer these for hours and still have no clue. Help is appreciated.
We don't do your homework problems for you here. Instead, we help you come to the solution yourself. When you posted this problem you were presented with a template. It would have helped if you had followed it. What are the relevant equations in this problem? What work have you done to solve the problem?
15K
14K
  • · Replies 20 ·
  • · Replies 20 ·
