Help with Couple of Calculus Problems
  • Context: Undergrad
  • Thread starter Thread starter BaNZai
    Calculus Couple
The discussion revolves around several calculus problems, including finding displacement from a velocity function, calculating work done on a spring, determining the area between curves, and finding volumes of solids of revolution. The scope includes analytical methods and mathematical reasoning.
  • Homework-related
  • One participant expresses confusion over three calculus problems and provides their attempted solutions, indicating uncertainty about their correctness.
  • Another participant suggests showing work to identify where the confusion lies.
  • A participant proposes integrating the velocity function to find displacement, suggesting a different result than the original claim.
  • For the spring problem, a participant advises using Hooke's Law to find the spring constant and calculate work done, emphasizing the need for clarity in variable definitions.
  • Another participant suggests drawing the curves for the area problem to better understand the limits and areas involved, recommending a method for calculating areas between curves.
  • A participant interprets the fourth problem about the solid's volume and suggests using the Pappus theorem, although they express uncertainty about the clarity of the original statement.
Participants do not reach a consensus on the correctness of the original solutions provided. Multiple approaches and interpretations are presented, indicating that the discussion remains unresolved.
Some participants note the importance of clearly defining variables and limits, as well as the need for visual aids in understanding the problems. There are also indications of potential misunderstandings in the problem statements.
Students seeking assistance with calculus problems, particularly those involving integration, work calculations, and volume of solids, may find this discussion helpful.
BaNZai
Hello, I am completely stumped by some of these problems, and have no where else to get help, can anyone help me with these problems? Any help would be greatly appreciated. Thank you very much.
1. The function v(t)=12t(squared) - 16t is the velocity in m/sec of a particle moving along the x-axis, where t is measured in seconds. Use analytic methods to find the particles displacement for 0<(greater than or equal to)t<(less than or equal to)5. (round to nearest 10m). (Note: just t is squared in the equation, and it's 0 to 5 including both 0 and 5) (I got 120m but it doesn't seem right)
2. A certain spring obeys Hooke's Law and requires a force of 10N to stretch it 8cm beyond its natural length. How much work would be done in stretching it to 12cm beyond its natural length? (Note: I got 90N*m but I'm not sure if it's right)
3. Find the area of the region enclosed by y=sin2x and y=cosx for -(negative)PI/2 greater than or equal to X less than or equal to PI/6. (I got -4.5 which seems completely wrong :frown: )
These next two I had no idea how to do
4. The base of a solid is the region between the line y=4 and the parabola y=x(squared). THe cross sections perpendicular to the x-axis are semi-circles. Find the volume of the solid.
5. A region is bounded by the lines: y=(square root of)X , y= X-2, and y=0. Find the volume of the solid generated by rotating this region about the x-axis.
THanks again for any help, sorry if it is too much.
Why don't you show your work so we can see where you're having trouble?
cookiemonster
For first question:
by integrating your velocity function, you'll get
4t^3 - 8t^2, with limits on t: 0 to 5 seconds
applying the limits, you'll get 300m which is surely not what you were getting
For your second question:
since, F = Kx
find K using F1 = 10 KN and x1 = 0.08m
Now using this K and x2=0.12 m find F2. Your required work done is '(1/2) F2 x2'
note: F2 or x2 doesn't mean a 'square'
Xishan
Suggestion:
use 0<=t<=5 instead of what you've written, this will make your question more readible
Xishan
So, your range of 'X' for the third question is
-pi/2 <= X <= pi/6
Now draw the two curves on a graph so that you have a clear idea of the shape of the two and hence the limits (I hope you haven't missed this elementry step for your problem) OK!
Next thing you must do is to calculate the areas in the positive and negative regions separately.
Now take a differential strip parallel to y with its upper and lower bounds defined by the two functions. the area of the strip is defined by (y2-y1)dx. Replacing y1 and y2 with the respective functions and knowing your limits on x, you can now evaluate the areas.
Xishan
Your statement of fourth question is not too clear, let me guess!
You have a half paraboid with its axis parallel to y OK!, limits on y are 0 to 4 and limits on x are defined by the funciton y = x^2
if this is what you mean then you can you can use the Pipus theorem to solve this problem. take half of this parabola then calculate its area and centroid, now multiply this area with the distance its centroid covers in order to complete the paraboloid by revolving around y axis. this distance should be 'pi(a)' where a is the centroid about y.
Xishan
  • · Replies 20 ·
  • · Replies 24 ·
  • · Replies 24 ·
