Help with Allen Head Cap bolts
  • Thread starter Thread starter Lock
    Bolts Head
The discussion centers on replacing low-quality Allen Head Cap bolts used in an aluminum headphone amplifier. The user identifies the bolt size as approximately 3/16 inch (3mm) wide with an Allen key size of 1.5-2mm, and estimates the length to be between 5mm and 10mm. A forum member advises that the cap screw is merely a head style on a standard bolt, suggesting that the user can find replacements at local hardware stores or through suppliers like McMaster-Carr.
  • Understanding of bolt sizing conventions (metric and imperial)
  • Familiarity with Allen Head Cap bolt specifications
  • Basic knowledge of tools for unscrewing bolts
  • Experience with sourcing hardware from suppliers like McMaster-Carr
  • Research Allen Head Cap bolt specifications and sizing standards
  • Visit local hardware stores to compare bolt sizes and styles
  • Explore online suppliers like McMaster-Carr for replacement options
  • Learn about different head styles of cap screws and their applications
DIY enthusiasts, audio equipment builders, and anyone looking to replace or upgrade hardware components in electronic devices.
Lock
Help with Allen Head Cap bolts...
Hi,
Received today a new headphone amp. It is aluminium construction and uses 4 allen cap bolts at each end to hold the case together. It is all good (was cheap), but the bolts used are clearly low quality and don't look right. I would like to replace them but can't find details on what size they are (head looks about 3/16 (3mm) wide, and allen looks like 1.5-2mm). I would imagine the bolt is only about 10mm long max, maybe more like 5mm. I will have to unscrew to check, but I don't want to do this until I'm reasonably sure I can replace.
I'm sorry if this is the wrong forum. Anybody advise on the sizing convention for these type of bolts (metric and imperial-Im not sure which these are), and where to buy replacements?
Many thanks in advance
Lock
Welcome to PF, Lock.
The cap screw is just a head style on a regularly sized bolt. You can get a replacement with just about any head style you want. Just take one down to your local hardware store and they'll set you up with a match.
Or try McMaster ones you know the style and code
17K
  • · Replies 18 ·
19K
