Discrete Math: Sets/Functions/Proofs
The discussion revolves around proving properties of functions and inequalities involving floor functions within the context of discrete mathematics, specifically focusing on functions between finite sets and properties of real numbers.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to prove that a function is one-to-one if and only if it is onto, exploring cases and considering proof by contradiction. They also present a second problem involving inequalities with floor functions and discuss dividing the proof into cases based on the values of certain variables.
Some participants question the completeness of the original poster's reasoning, particularly regarding the necessity of considering infinite sets in the first problem. There is an acknowledgment that the original poster's approach may not fully utilize the properties of finite sets, prompting further exploration of definitions and implications.
The original poster expresses uncertainty about their methods and the implications of their assumptions, particularly regarding the finite nature of the sets in the first problem and the handling of cases in the second problem.
opt!kal
I apologize for the title, I really don't know how to describe these problems, so I just listed the categories that they fall under. Anyways...
Let f: A->B be a function, where A and B are finite sets and |A| =|B| (they have the same size I believe). Prove that f is one-to-one if and only if it is onto.
Nothing comes to mind.
I apologize in advance for the length, apparently writing it out into 2 giant paragraphs was the only way I could get through this problem"
Since the problem takes the form p iff q, we basically have two cases, p ->
q and q -> p, where p is f is an one-to-one function and q equates to f is
an onto function. CASE I - p->q:
First let us assume that p is true, in other words, f is an one-to-one
function. Since f is 1-1 we know that each element in the co-domain will be
mapped into either 0 or 1 times, depending on the size of both the domain,
and co-domain. However, since we know that |A|=|B|, we know that the number
of elements in the domain (A) is equal to the number of elements in the
co-domain (B). By our definition of what a 1-1 function represents, we know
that each element in the co-domain will be mapped into one time (we know
this because since the sizes are equal, and some element in the co-domain
was not mapped into, it would mean that were exists an a and b within A
such that f(a)=c and f(b)=c for some element in c, which would not make the
function 1-1). We also know that a function is onto if for every element b
that resides in the co-domain, there is an element a within the domain such
that f(a)=b. Since we know that every element in the domain (A) must map
once into an element in the co-domain (B), we see that the function is
onto. Therefore we have shown that if f is 1-1 then f is onto.
CASE II- q->p:(Basically what I am thinking of doing is proof by
contradiction, so something like q ^!p) Proof by contradiction: Let us
assume that the statement,"if f is onto, then it is 1-1" is false, so that
we end up with the form q ^!p. Therefore we have, "f is onto, and f is not
1-1." Since f is onto, then we know that for every element in the
co-domain, there is an element in the domain such that f(a)=b. This means
that every element in the co-domain is mapped into one or more times. We
know that if there are elements in the co-domain that are being mapped into
more than one time, then it would mean that the domain itself has a fewer
number of elements than the co-domain. However, we know that this cannot
happen, since it was stated that |A|=|B| Therefore we know the statement "f
is onto and f is not 1-1" is false, which would mean that if f is onto,
then f must be 1-1.
Basically I am not really confident in how I did the second case. I don't know
if I can do proof my contradiction, and if I can't, then what method should
I think about in order to show this? Also, does the first half seem
alright?
Anyways, on to the second problem...
Prove that, for any reals x and y, [x] + [y] + [x + y] ≤ [2x] + [2y] (I apologize, the brackets are supposed to represent the floor symbol, I tried using latex, but it said the right floor was an invalid image, and made everything look weird, so I figure this should be a bit less confusing.)
Hint: Let x = n+[tex]\epsilon[/tex] and y = m+[tex]\delta[/tex], where n = [x] and m = [y] and 0 ≤ [tex]\epsilon[/tex], [tex]\delta[/tex]< 1. Consider
dividing your proof into two cases: one where [tex]\epsilon[/tex] and [tex]\delta[/tex] are both less than 1/2 and the other
where they are not (i.e., at least one is greater than or equal to 1/2)
As of now I have:
CASE I: So basically I have [x] + [y] + [x + y], which
would be something like: n + m + [n +[tex]\epsilon[/tex]+m +[tex]\delta[/tex]] however, since we know
that [tex]\epsilon[/tex],[tex]\delta[/tex] is less than 1/2, they should become 0 due to the floor function,
so basically we have n + m + [n + 0 +m +0]= n + m + n + m = 2n + 2m, right?
and since the right hand side is equal to [2x] +[2y], we will have
something like 2n + 2m meaning that our equation is 2n + 2m <= 2n + 2m. Is
that what I have to do for the first case? I'm kinda confused as to what our end result is supposed to be for each case. In addition, do you have any tips on how to tackle the second
case? Any help would be appreciated. Thanks in advance,
For the first part, nothing you have written is false in the case of finite sets. But it's sort of mushy and vague. Because it never explicitly uses the fact that the sets are finite. Reread it, thinking about the case where A and B are infinite, in which case the conclusion is FALSE, and try to figure out what to do about it. What's the definition of finite and infinite?
Do I have do consider the infiite case? I just thought since it stated within the problem that the sets were finite, that was what I should focus. In any case, I will give it some thought and get back to you.
Dick's point is that you don't use the fact that your sets are finite. And, since the statement is false for infinite sets, any proof that doesn't use the fact that the sets are finite can't be correct.
