Build Cyclotron: Find 12" Neodymium Disc Magnet
  • Context: Undergrad
  • Thread starter Thread starter The_Brain
    Cyclotron Magnet
The discussion revolves around the construction of a small cyclotron, specifically focusing on the search for a suitable neodymium disc magnet to serve as the two 'D' magnets. Participants explore various options for sourcing magnets and debate the necessity of using permanent versus electromagnets in the design.
  • One participant seeks a 12" neodymium disc magnet to cut in half for use in a cyclotron.
  • Another participant advises against cutting neodymium alloy at home due to its hardness and suggests using two separate magnets instead.
  • A different perspective proposes starting with a high-voltage linear accelerator instead of a cyclotron.
  • There is a claim that the 'dees' in a cyclotron should be electromagnets rather than permanent magnets.
  • A participant expresses confidence in their understanding of the necessary equations and previous experience with a linear accelerator.
  • Some participants clarify that while the dees are not permanent magnets, a strong permanent magnet is still needed to curve the paths of particles in a cyclotron.
  • One participant mentions having discarded a large electromagnet, indicating a missed opportunity for the project.
Participants express differing views on the necessity of permanent magnets versus electromagnets for the cyclotron's design. There is no consensus on the best approach to sourcing the required magnets or the overall design strategy.
Participants reference various types of magnets and their properties, but there are unresolved questions about the specifics of magnet selection and the design requirements for the cyclotron.
The_Brain
I'm trying to build a small cyclotron and am thus searching for a magnet. I've been looking for a neodythium disc magnet that I could have cut in half to act as the two 'D' magnets in the cyclotron. The size of the magnet needs be somewhere around 12" in diameter but I can't seem to find anyplace that sells them around this size. If anyone knows where I could find some magnets or is willing to sell some of their own that would be great.
A couple of advices.
1.Don't try to cut neodym alloy - you won't be able to do that at home (it is very and very hard alloy). Ferrite is a little better, but too brittle. So, just get 2 magnets instead.
2. If you can't find two large magnets (equipment surplus web places can be a good place to start a search - Ti ion vacuum pumps have quite big slabs of ferrite magnets), then buy many small magnets and make a big one.
why don't you start with a high-voltage linear accelerator and see how that goes first? you just need a very strong tube, a pump, and a voltage difference from either transformer or van de graff generator.
The dees will need to be electromagnets, not permanent magnets.
- Warren
That's true, they will. And you might want to consult relavant physics textbook for equations and etc.
Thanks for all of the responses. First off, I've already built a linear accelerater using my own voltage multiplier I made, a pump, etc. I also know all the equations for figuring out the frequency I need to alternate the current, what the velocity of the particle given a certain strength of a magnetic field is and the length of path taken, etc.
When I first started thinking about this, I too thought I needed elctromagnets but then my high school physics teacher told me I needed permanent magnets. Thus, I was hoping to find a strong neomydium magnet disc that I could have someone professionally cut into two parts so I could have my two dee magnets. I guess now I need to search out for electromagnets, so if anyone knows where some are, that would be great!
- Warren
That is for synchrotron. For cyclotron an orbit just gets bigger and bigger with velocity.
Originally posted by Alexander
That is for synchrotron, not cyclotron.
Er, uh...
You'll still need a strong permanent magnet to curve the paths of the particles (ions, electrons, etc.) in a cyclotron.
However, the poster was asking about the DEES -- which are, of course, not permanent magnets. They are, in fact, not magnets at all. The dees are two halves of a hollow metal disc, to which an oscillating electric potential is applied.
- Warren
If only I would have read this a few hours before. I just tossed a huge electromagnet.
JMD
  • · Replies 16 ·
  • · Replies 23 ·
18K
