Fairly simple rolling and slipping ball problem.
The discussion revolves around a problem involving a ball rolling and slipping on a ramp. The ball, characterized by its radius and mass, is analyzed as it transitions from sliding on a horizontal surface to rolling without slipping up an inclined ramp. Participants are tasked with deriving expressions for angular velocity and time taken to stop sliding, while considering energy conservation and frictional forces.
  • Mixed
  • Participants explore energy conservation principles, relating initial and final kinetic energies to derive expressions for angular velocity and time. There are attempts to clarify the conditions under which the ball transitions from sliding to rolling.
Some participants have provided insights into the relationships between kinetic energy, frictional forces, and the conditions for rolling without slipping. There is an ongoing exploration of the equations involved, with participants questioning the validity of certain assumptions and the implications of their derived expressions.
Participants note the complexity of the problem due to multiple unknowns and the need to relate them through the equations of motion and energy. There is a mention of potential corrections to initial assumptions regarding the moment of inertia and the nature of the forces acting on the ball.
cpfoxhunt
A ball radius r mass m starts rolling without slipping up a ramp inclinced at an angle phi to the horizontal, and reaches a maximum height, h. Derive an expression for the angular velocity, omega, that the ball has at the base of the ramp (ignore rolling friction throughout question.).
b) The ball is initially launched without rotation towards the ramp on a horizontal surface with a coefficient of sliding friction, mu. The ball slides along the surface, begins to roll, and stops slipping before it reaches the ramp. Find an expression for the time, t, raken for it to stop sliding in terms of h, g and mu.
c) by considering the initial velocity v0 and the resistance felt by the ball before it begins to roll, derive an expression relating its initial and final energies in terms of the sliding distance s.
find x, v0, and t taking values h = 0.25m, r = 2cm, m = 50g and mu = 0.3
When something undergoes pure rolling motion, v = rw
- w = omega u = mu
a) Energy at top = mgh. mgh = 1/2 * mv^2 + 1/2 Iw^2 . I know that as it is rolling, v = rw, and solve to get omega = (10gh/7(r^2))^(0.5) (using I = 2/5 ma^2 if a is the radius)
b) here's where it gets a little dodgy - I assume that there is a rotational equation even though it is sliding (i.e. that it is rotating a little bit but not pure rotation) - is this valid?
I(dw/dt) = umgr , integrate once w.r.t time to get w = t(5ug/2r) where the moment of inertia for a sphere has been used. I then equate this to my earlier figure from a), and get (8h/35gu^2)^(0.5) - is this right?
c) I say that initial energy = 0.5m(v0)^2 and this minus the final energy of slipping (equal to 1/2 * I * w^2 where w is the omega in a) ) = Fx where F is the resistive force during the slipping, and x is slipping distance.
I can then work out t pretty easily, and am not sure how to get X and v0.
Any help is very greatly appreciated,
Cheers
Cpfoxhunt
EDIT: i initially did this using I for a disk (where I is inertia), and have corrected it a bit hurriedly - some of my multiplying fractions might be a bit out?
The sliding frictional force stops acting as soon as rolling without slipping is achieved, and v becomes equal to rw.
The work F*x done by the frictional force should be equal to the (initial KE-final KE). The final KE should be (1/2)Iw^2+(1/2)mv^2, where v=rw.
The rest of the work looks very correct.
Hi, thanks for the reply. I used that relation to work out part a), and now have a single equation Fx = unknown initial ke (v0 dependent) - known final ke. there are three unknowns which I am asked to calculate here. How can I calculate them?
Cheers
Cpfoxhunt
[(½)mv0^2 - {(½)mv^2 + (½)Iw^2} = µmg*x. This is the one you have used, I think.]
It starts to roll due to sliding friction. The sliding friction stops once v=rw is reached.
For the time when it is sliding and rolling, you have to use (for the rotational motion),
F*r = I(dw/dt) until w becomes v/r from zero, and,
F = m(d^2x/dt^2), until the velocity becomes v from v0, and x goes from 0 to x.
um...is v not constantly equal to rw? because the ratio of linear velocity and angular is constant?
  • · Replies 60 ·
  • · Replies 42 ·
  • · Replies 21 ·
  • · Replies 32 ·
  • · Replies 17 ·
  • · Replies 24 ·
