Thread Closed
A Proton is orbiting a metal ball
Share Thread Thread Tools
Apr9-08, 02:07 PM   #1
A proton orbits a 1.0-cm-diameter metal ball 1.90 mm above the surface. The orbital period is 1.50 [tex]\mu s[/tex].
What is the charge on the ball?
2. Relevant equations
[tex]F_{cp} = \frac{m v^2}{r}[/tex]
[tex]F_c = \frac{k q_1 q_2}{r^2}[/tex]
3. The attempt at a solution
Since the proton is orbiting the metal ball, there is obviously a centripetal force involved, but first I need to velocity.
[tex]v_{cp} = {\omega r} = \frac{2 \pi r}{T} = \frac{2 \pi (0.005)}{1.5*10^{-6}} = 2.1*10^4 m/s[/tex]
I was wondering whether this statement is true [tex] F_{cp} = F_c[/tex]
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Apr9-08, 04:40 PM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
You're on the right lines, just keep going. One issue is your value for r?
Apr9-08, 05:54 PM   #3
so would q_1 = q_2 in this case, and for the r, I should use the 1.9mm instead?
Apr9-08, 06:06 PM   #4
Recognitions:
You'll be solving for for one of the charges. The other will be the charge on the proton. The radius if measured from the centre of the metal sphere.
Apr9-08, 06:29 PM   #5
so the radius of the metal ball would be .5 cm = 0.005m which is the value I used.
Apr9-08, 06:33 PM   #6
Recognitions:
Quote by cse63146 View Post
Plus the distance of the proton above the surface.
Apr9-08, 07:13 PM   #7
Quote by Kurdt View Post
to calculate the velocity needed for the centripetal force?
Apr9-08, 07:32 PM   #8
Recognitions:
Yes.
Apr9-08, 07:35 PM   #9
I don't see why I would need the distance of the proton from the surface.
Apr9-08, 07:37 PM   #10
Recognitions:
The r is the distance of the proton from the centre of rotation. The distance is the radius of the sphere plus the height above the surface.
Apr12-08, 12:25 PM   #11
so F_cp=(mv^2)/r
and F_cp=F_c
so F_cp=(kq_1q_2)/r^2
also q_1=q_2 --> F_cp=(kq^2)/r^2
Is this right?
Apr12-08, 12:34 PM   #12
Recognitions:
If you're doing the same question you can't assume both charges are the same since it is one of the charges you are trying to find.
Apr12-08, 12:41 PM   #13
r = 1.0cm + 1.9 mm = 1.19 cm = 0.0119 m
m_proton = 1.67*10^-27 kg
T = 1.5 us = 1.5*10^-6 s
v_cp = omega*r = (2pi*r)/T = [2pi(0.0119 m]/(1.5*10^-6) = 4.98*10^4 m/s
F_cp = (mv^2)/r = (1.67*10^-27 kg*(4.98*10^4 m/s)^2)/0.0119 m = 3.49*10^-16 N
F_cp = F_c
F_cp=(kq^2)/r^2
3.49*10^-16 N = (k*q^2)/r^2
q^2 = [(3.49*10^-16 N)(r^2)]/(k)
q^2 = [(3.49*10^-16 N)((0.0119m)^2)]/(k)
q^2 = 4.937*10^-20 Nm^2 / 8.99*10^9 Nm^2/C^2
q^2 = 5.49*10^-15 C^2
q = 2.34*10^-15 C
Is this the correct procedure and answer? Someone plz help
Apr12-08, 12:42 PM   #14
I just saw your reply as I entered this post above, what am I doing wrong?
Apr12-08, 12:45 PM   #15
radius would be r = 1/2(0.019 m) = 0.0095 m
Apr12-08, 12:46 PM   #16
no wait, r = 1/2(1 cm) + 1.9 mm = 0.0069 m
Apr12-08, 12:51 PM   #17
new calculation:
r = r = 1/2(1 cm) + 1.9 mm = 0.0069 m
v_cp = omega*r = (2pi*r)/T = [2pi(0.0069 m]/(1.5*10^-6) = 2.89*10^4 m/s
F_cp = (mv^2)/r = (1.67*10^-27 kg*(2.89*10^4 m/s)^2)/0.0069 m = 2.02*10^-16 N
F_cp = F_c
F_cp=(kq^2)/r^2
2.02*10^-16 N = (k*q^2)/r^2
q^2 = [(2.02*10^-16 N)(r^2)]/(k)
q^2 = [(2.02*10^-16 N)((0.0069m)^2)]/(k)
q^2 = 9.62*10^-21 Nm^2 / 8.99*10^9 Nm^2/C^2
q^2 = 1.07*10^-30 C^2
q = 1.03*10^-15 C
Thread Closed
Thread Tools
Similar Threads for: A Proton is orbiting a metal ball
Thread Forum Replies
photon-proton/ proton-electron interactions Quantum Physics 34
[SOLVED] negative rod to uncharged metal ball: Introductory Physics Homework 6
metal ball on a ramp Introductory Physics Homework 1
What causes a metal ball to fall faster than a feather on earth? Introductory Physics Homework 6
relativity - proton-proton collision Advanced Physics Homework 2
