Finding Magnetic Field: A Circular Path Challenge
The problem involves a singly charged positive ion moving in a circular path, with the goal of determining the direction and strength of the magnetic field acting on it. The context is rooted in concepts of circular motion and magnetic forces.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the relationship between magnetic force and centripetal force, with some attempting to derive the necessary formulas. Questions arise regarding the nature of acceleration in circular motion and its relationship to velocity.
The discussion is ongoing, with participants exploring various formulas related to magnetic forces and centripetal motion. Some guidance has been offered regarding the need to couple different formulas, but no consensus has been reached on the correct approach.
There are indications of confusion regarding the definitions of acceleration and its direction in circular motion, as well as the need for clarity on the formulas required for the problem.
lettertwelve
A singly charged positive ion with a mass of 6.68 x 10^-27 kg moves clockwise with a speed of 1.10 x 10^4 m/s in a circular path with a radius of 2.00 cm. Find the direction and strength of the magnetic field. (Hint: The magnetic force exerted on the ion is the force that maintains circular motion, and the speed of the ion given is its tangential speed.)
_____ T
F = ma and since the particle travels in a circle, F = mv² / r which is the magnitude of the magnetic field.
F = 6.68•10^-27 kg•(1.10•10^4 m/s)² / 0.2m
but the answer is wrong.
why?
What is the formula for finding the force exerted by a magnetic field on a charged particle?
When you find that formula, that provides the centripetal force to keep it in a circle.
. . . i obviously have no idea ?
force exerted by a magnetic field on a charged particle?= BQv
B=magnetic flux density
Q=charge of particle
v=velocity of particle.
Lol maybe you should've done a bit more research, at least to figure out the needed formulas. Wikipedia is often a good source.
F=ma...How would you go about finding the Acceleration? Are you finding the Accel of the Ion? And if so, does it even HAVE an acceleration?
yes it does have an acceleration...but perpendicular to the velocity =)
Perpendicular? I don't even know how that happens. Does "Perpendicular to the Velocity" just mean the object is turning? How does Accel go about being perpendicular to Velocity? try to give an example? Because I assumed that the object maintained the same speed (1.10 x 10^4 m/s), in which case the acceleration would be 0.
The centripetal force causes the acceleration to be inward towards the center of the circle. He's right that the instantaneous velocity is tangential to the acceleration.
Anyway, you don't need to find the acceleration. Couple the formula that you know with rock.freak667's formula.
yeah, I was going to say that the other formula makes more sense.
So much about Physics seems arbitrary right now. Like, gravity. There's no real reason why 2 masses attract one another.
  • · Replies 31 ·
  • · Replies 21 ·
