Thread Closed
minumum rope length
Share Thread Thread Tools
Apr10-08, 02:52 AM   #1
minumum rope length
The rope connected to the triangle is pulling away at 3000N
i need to determine the minimum length of ac so that the tension in either ab or ac does not exceed 4000N. AC and BC are the same length.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Apr10-08, 03:37 PM   #2
can someone please just tell me the equation that relates rope length to tension.
Apr10-08, 04:49 PM   #3
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Hi Ry122!
I don't understand … your diagram says BC = 5m, and angles BCA and CBA are 30º.
So AC is fixed, isn't it?
What am I missing?
Apr10-08, 05:08 PM   #4
minumum rope length
oops, I made a mistake. angle CBA is unknown and length BA is different from AC
Apr10-08, 05:19 PM   #5
Is the tension in the rope pulling away (3000N) equal to the tension in BC? if so ill know how to answer the question
Apr10-08, 05:24 PM   #6
Recognitions:
Quote by Ry122 View Post
No, certainly not.
You have to use Newton's second law: sum of the forces in any particular direction is zero.
But I still don't understand what stops the triangle from rotating.
Apr10-08, 05:34 PM   #7
a large mass is attached to the triangle at BC.
Apr10-08, 05:39 PM   #8
Recognitions:
Sorry … this is no good.
Will you please type out the whole original question?
Apr10-08, 05:41 PM   #9
sure
The tension in the tow rope pulling the car in Newtons is 3000N. Determine the minumum length of the rope l, between A and B, so that the tension in either AB or AC does not exceed 4000N
Apr10-08, 05:48 PM   #10
Recognitions:
So where does the 30º come into it? Or is that gone too?
Is angle CAB unknown as well as angle CBA?
Apr10-08, 05:56 PM   #11
angle CBA = theta
angle BCA = 30 degrees
BA = l
BC = 1.2m
Sep15-08, 09:26 AM   #12
can anyone help me with this?
Sep15-08, 10:28 AM   #13
Sep15-08, 01:04 PM   #14
Recognitions:
Quote by gozita73 View Post
You need to show your attempt first.
HINT: Start by breaking the forces down into x and y components, then solve the equations for the desired unknown. Initially, the desired unknown will be theta. Once you have theta, you can use a little trig to find the length, L, which is what you truly desire.
CS
Sep15-08, 04:45 PM   #15
I get:
Sum of Fx
0 = Fab cos (theta) + Fac cos (30)
Sum of Fy
0 = Fab sin (theta) + Fac cos (30) - 3000N
Would Fab and Fac equal max. tension (4000N)? otherwise, I'm completely stuck
Sep16-08, 08:22 AM   #16
Recognitions:
I get:
Sum of Fx
Sum of Fy
Check your FBD again, your component equations do not look correct. Once you solve the x-component equation you will be able to substitute that result into the y-component equation, which will leave only one unknown, theta (along with the assumption that one of the lines is at the max allowable tension of 4000N).
CS
Sep16-08, 08:35 AM   #17
I've been staring at those equations for quite a while now...
all i can see is that:
In the x-axis:
Fab cos(theta) = -Fac cos(30)
and in the y-axis:
3000N = Fab sin(theta) + Fac sin(30)
I know through the sin rule that:
sin (theta)/ Fac = sin (30)/Fab
but I don't know how the unknown length, l, can fit in
Thread Closed
Thread Tools
Similar Threads for: minumum rope length
Thread Forum Replies
How can the Planck length be claimed to be the smallest length? General Physics 47
Cutting equal numbers of different length pieces from a known length Linear & Abstract Algebra 4
The maximum and minumum Current Engineering, Comp Sci, & Technology Homework 2
length of the rope around two circles Precalculus Mathematics Homework 6
I can't see how stress-energy tensor meets the minumum tensor requirement Special & General Relativity 4
