Is My Understanding of Factorial (2n+1)! Correct?
  • Context: Undergrad
  • Thread starter Thread starter motornoob101
    Factorial
The discussion revolves around the understanding of the factorial notation, specifically (2n+1)!, and its relationship to previous terms in the sequence. Participants explore the correct formulation of factorials and their application in series convergence tests.
  • One participant claims that the previous term of (2n+1)! should be (2(n-1)+1), leading to the expression (2n+1) = (2n+1)(2n-1)!.
  • Another participant counters that the previous term should be (2n + 1) - 1, not (2(n-1) + 1), and provides a general rule for rewriting factorials.
  • A third participant expresses confusion stemming from a ratio test example, questioning the similarity between the factorial operation and the manipulation of terms in the series.
  • A later reply indicates that there is a misunderstanding between terms in the sum and terms within the factorial.
Participants do not reach consensus on the correct interpretation of the factorial notation and its application, with multiple competing views presented.
There is a potential misunderstanding regarding the definitions and operations of factorials and their relation to series terms, which remains unresolved.
motornoob101
For the factorial (2n+1)!, I thought the previous term is going to be (2(n-1)+1), which is equal to (2n-1).
Thus (2n+1)!= (2n+1)(2n-1)!
However, in the textbook, they have it as .
[tex]a_n= \frac{(2n-1)!}{(2n+1)!}=\frac{(2n-1)!}{(2n+1)(2n)(2n-1)!}[/tex]
Are they wrong or I am wrong? Thanks!
Mathematics news on Phys.org
The previous term of (2n+1) is (2n + 1) - 1 not (2(n-1) + 1).
In General if you have (f(x))! You can rewrite as f(x)*(f(x) - 1)!
What you tried which is incorrect is f(x)(f(x-1))!
See the difference?
Ah ok. I see thanks. The reason I thought I was correct because I was looking at this example..
Which they are trying to determine if a series is convergent/divergent by the ratio test
Notice how they change 2n-1 to 2(n+1)-1? That's what confused me. Now I know they do it because it is the ratio test and you are trying to put [tex]a_{n+1}[/tex] but isn't that the same as what the factorial is doing? Thanks.
You are confusing terms in the sum, and terms within the factorial.
  • · Replies 19 ·
