| Thread Closed |
Rigid Object Under Torque |
Share Thread |
| Apr10-08, 04:04 PM | #1 |
A grinding wheel is in the form of a uniform solid disk of radius 7cm and mass 2kg. It starts from rest and accelerates uniformly under the action of the constant torque of 0.6 Nm the motor exerts on the wheel. a) How long does the wheel take to reach its final operational speed of 1200 rev/min? b) Through how many revoulutions does it turn?
Torque= (m*r^2)*circular accel. circular veloc. Final= circ.veloc. Intial + circular accel.*time Ok, so I tried to use the above torque equation to solve for circular acceleration. So, .6/(2*.07^2) = circular accel.= 61.22 rad/s. Then I tried putting that value back into the other equation. So, 125.66 rad/s(I converted it)-0=61.22*t. Thus, t=2.06s. However, the time I am supposed to get is 1.03s (half of what I got). Could someone please explain where I went wrong? |
| Apr10-08, 04:48 PM | #2 |
the equation for torque is [tex]\tau=I\alpha[/tex], and for a disk rotating about its axis, [tex]I=\frac{1}{2}MR^2[/tex].
i think that should solve your problem. cheers |
| Apr10-08, 05:06 PM | #3 |
Thank you that solved the problem!
| Thread Closed |
Similar discussions for: Rigid Object Under Torque
| torque on a rigid body | Introductory Physics Homework | 1 | ||
| rigid object in equilibrium | Introductory Physics Homework | 3 | ||
| Rigid Bodies including topics of power and torque. | Introductory Physics Homework | 4 | ||
| Rolling Motion of a Rigid Object | Introductory Physics Homework | 7 | ||
| Rolling rigid object | General Physics | 1 | ||
