| Thread Closed |
two pulley system |
Share Thread | Thread Tools |
| Apr11-08, 01:06 AM | #1 |
two pulley system![]() Does the tension in the rope from B to A and from A to C remain the same? To determine the value of theta when the system is in equilibrium do I need to calculate the sum of all acting x and y components? If so would B and C be negative and A be positive? |
| Apr11-08, 10:46 AM | #2 |
Recognitions:
In this case, the weight of A is balanced by the resultant of the two tensions, which in turn are equal to the weights of B and C respectively. (The pulleys are assumed to be frictionless, and I've just given you the method of solving the problem.) |
| Apr11-08, 04:15 PM | #3 |
if B and C are not negative then what is? something has to be negative otherwise the sum of the system won't be equal to zero.
do i just use a right triangle to solve for the resultant? |
| Apr11-08, 04:45 PM | #4 |
two pulley system
are B and C positive and A negative?
| Apr11-08, 04:47 PM | #5 |
Recognitions:
I didn't quite understand your 2nd Q. Do you mean how to solve for the forces at where A is hanging from? Break up into horizontal and vertical components, and then equate the sums to zero. |
| Apr11-08, 05:00 PM | #6 |
does this look right
Bsin(theta)+Csin(phi)-A=0 Bcos(theta)-Ccos(phi)=0 so i dont even have to find the resultant tension i just solve for theta? |
| Apr12-08, 02:18 AM | #7 |
Recognitions:
| Thread Closed |
| Thread Tools | |
Similar Threads for: two pulley system
| Pulley system | Introductory Physics Homework | 2 | ||
| Pulley System | Introductory Physics Homework | 0 | ||
| Pulley System | Introductory Physics Homework | 2 | ||
| Two pulley system | Introductory Physics Homework | 14 | ||
