Prove x^{k+1}-1=(x-1)(x^{k}+x^{k-1}+...+1) by Induction
  • Thread starter Thread starter dtl42
    Induction
The discussion revolves around proving the equation x^{k+1}-1=(x-1)(x^{k}+x^{k-1}+...+1) by mathematical induction. Participants are exploring the validity of the inductive step based on a previously established result, x^{k}-1=(x-1)(x^{k-1}+x^{k-2}+...+1).
  • Some participants attempt to substitute terms and expand expressions, while others question the validity of their approaches. There are discussions about dividing expressions and simplifying fractions, as well as exploring alternative methods without division.
The discussion is ongoing, with participants providing various insights and suggestions. Some guidance has been offered regarding the use of induction and alternative substitution methods, but no consensus has been reached on a specific approach.
Participants are working under the constraints of proving the statement by induction, and there is a focus on the assumptions made in the inductive step. The challenge of simplifying expressions and finding appropriate substitutions is also noted.
dtl42
Prove by Induction that [tex]x^{k}-1=(x-1)(x^{k-1}+x^{k-2}+...+1)[/tex]
None? I need to prove [tex]x^{k+1}-1=(x-1)(x^{k}+x^{k-1}+...+1)[/tex] by assuming this is true: [tex]x^{k}-1=(x-1)(x^{k-1}+x^{k-2}+...+1)[/tex]
[tex]x^{k+1}-1=(x-1)(x^{k}+x^{k-1}+...+1)[/tex] - I tried substituting in the [tex]x^{k}[/tex] term, and expanding [tex]x*x^{k}-1[/tex], but it failed.
You can't use that- that's what you are trying to prove.
You have xk+1- 1 and you need to use the fact that xk- 1= (x-1)(xk-1+...+ x+ 1). Have you tried dividing xk+1-1 by xk- 1? It does not divide evenly, you get
[tex]x^{k+1}-1= (x^k-1)(x+1)+ \frac{x-1}{x^k-1}[/tex]
but now you should be able to simplify that fraction.
That fraction would simplify to [tex]\frac{1}{x^{k}+x^{k-1}+...+1}[/tex] right?
Bump, I could use some help
Check the power of the leading term in the denominator again.
there is another method without any division. When you have [tex]x^{k+1}-1=x \cdot x^k-1[/tex], substitute the x part inte another appropriate term that equals x, then use the induction assumption.
What would the other appropriate term be? I can't really work that out in my head, I thought I should substitute for [tex]x^{k}[/tex] because I can separate it more easily.
I can give you an example of what technique I mean.
Prove that [tex]3^{2n+1} + 4^{2n+1}[/tex] always is divisible by 7.
Indcution. True for n=0, now assume true for n and consider n+1:
[tex]a_{n+1}=3^{2(n+1)+1} + 4^{2(n+1)+1}=9\cdot 3^{2n+1}+16 \cdot 4^{2n+1}=[/tex]
[tex]=9\cdot 3^{2n+1}+(9+7) \cdot 4^{2n+1}=9 \cdot a_n + 7 \cdot 4^{2n+1}[/tex]
which is divisible by 7 if a_n is.
How can you apply this method on your problem? how can the two terms look like, if they should equal x? :)
