Breakdown Voltage of PN Junctions: P+-N vs. N+-P
  • Thread starter Thread starter Fermi_98
    Voltage
The discussion centers on the breakdown voltage of PN junctions, specifically comparing p+-n and n+-p diodes under identical design parameters such as doping concentration and thickness. It is established that the p+-n diode typically exhibits a higher breakdown voltage due to the higher doping concentration of the p-type material, which enhances the electric field strength at the junction. The notation used in the discussion, such as p+nn+, is clarified as a common representation in power rectifiers, indicating the doping levels of the semiconductors involved.
  • Understanding of semiconductor physics, particularly PN junctions
  • Familiarity with doping types and levels in semiconductors
  • Knowledge of breakdown voltage concepts in diodes
  • Experience with power rectifiers and their applications
  • Research the impact of doping concentration on breakdown voltage in diodes
  • Learn about the characteristics and applications of power rectifiers
  • Explore the differences between p+-n and n+-p diode configurations
  • Investigate the role of electric fields in semiconductor junctions
Electrical engineering students, semiconductor physicists, and professionals involved in designing and analyzing diode circuits, particularly in high-voltage applications.
Fermi_98
Hiya,
Being a computer science and eng first year student, just trying to understand one artical regarding Breakdown voltage of a pn junction.Could anybody explain me, which diode out of the following have higher breakdown voltage if they have same design parameters such as doping and thickness and why ?
1. p+-n diode
2. n+-p diode
Fermi_98 said:
Hiya,
1. p+-n diode
2. n+-p diode
Can you clarify your diode notation. It seems ambiguous.
Chris
I suppose, i should have rather written as p+nn+. If you are familiar with power rectifiers, it is quite common notation used in there, to denote the high voltage rectifier.
High voltage rectifiers are fabricated in silicon which is either n-type or p-type.
1. "p" refers to quantity of the p-type semiconductor for instance boron etc. The + sign shows that boron atoms concentration, we are talking is in the order of greater then 1e18 cm-3 .This much of the boron atom concentration is diffused into the n type silicon to make a rectifier. It is therefore denoted by p+n.
2. like wise "n " refers to n-type semiconductor for instance phosphorous etc. Again, when the doping concentration is very high, we denote it by n+.
so same is applicable to other type of the rectifier for instance n+pp+.
16K
