Directional Derivative for Linear Maps
The discussion revolves around the concept of directional derivatives in the context of linear maps, specifically focusing on a problem that involves showing that the directional derivative of a linear map is equal to the map itself at any point in its domain.
  • The original poster seeks guidance on how to approach the problem, expressing uncertainty despite understanding the general concept of directional derivatives. Some participants suggest starting with definitions, while others inquire about the specific definition of the directional derivative and its application to linear maps.
The discussion includes attempts to define the directional derivative and relate it to the properties of linear maps. One participant shares their progress in deriving the expression for the directional derivative, while another provides a brief confirmation of the use of LaTeX for notation. There is an ongoing exploration of the definitions and implications without a clear consensus on the correctness of the approach taken.
The original poster indicates that they have successfully solved similar problems but are struggling with this particular one. There is a mention of potential follow-up questions, suggesting that the discussion may continue to evolve as participants engage further with the problem.
asif zaidi
Hi:
Can someone point how to approach this problem- we had 5 problems on directional derivatives and I solved 4. I understand the concept but in this question I don't know where to begin
Problem Statement
Assume that f:R[tex]^{n}[/tex] -> R[tex]^{m}[/tex] is a linear map, with matrix A with respect to the canonical bases. Show that Df(xo) = f for every xo [tex]\in[/tex] R[tex]^{n}[/tex]
Plz advise - I will probably post follow-up questions to any answers
Thanks
Asif
You should never be at a loss of how to begin a problem -- definitions are almost always a reasonable starting point.
Specifically, what is the definition of "Df" and what happens when you apply that definition to a linear map?
I will give what I have done so far...
Definition of a directional derivative is its partial derivatives wrt to all the variables in the given function.
So in this case the question is for f:R[tex]^{n}[/tex]->R[tex]^{m}[/tex] there is an mxn matrix which would look like the following
Df(x0) = (assume this is equation 1)
df1/dx1 df1/dx2... df1/dxn
df2/dx1 df2/dx2... df2/dxn
dfm/dx1 dfm/dx2...dfm/dxn
Where in above matrix dfm/dx1 is the partial derivative of function wrt x1,x2... I couldn't find symbol for partial derivative
Now, if I use the definition of a linear map then I know that
D([tex]\alpha1[/tex]+[tex]\alpha2[/tex] ) f(x0) = [tex]\alpha1[/tex]Df(x0) + [tex]\alpha2[/tex] Df(x0)
I can also prove by continuity and as t->0 and [tex]\varsigma[/tex]->0 that
Df(x0 + [tex]\varsigma[/tex]p1 + t[tex]\alpha2[/tex]p2) -> Df(x0) ----- equation 2
Now since this is a canonical map the above matrix of Df(x0) in equation 1 reduces to the following
1 0... 0
0 1... 0
0 0...1
So in equation2 since D is essentially the above matrix, I can say the following:
Df(x0 + [tex]\varsigma[/tex]p1 + t[tex]\alpha2[/tex]p2) -> f(x0) which is what I think the question wants.
Is this correct?
Thanks
Asif
Yes.
(in LaTex, [ tex ]\partial[ /tex ] gives [tex]\partial[/tex].)
  • · Replies 24 ·
