Thread Closed
I heard that if you took a peice of the sun the size of a pinpoint...
Share Thread Thread Tools
Apr13-08, 05:18 PM   #1
that it would burn everying in a 90 mile radius, or something like that, is this correct? Would this be the same as if the equivelant amount of hydrogen atoms fused all at once together?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Apr13-08, 07:15 PM   #2
It doesn't sound right, where did you hear this?
You could have quite a bit of hydrogen in the size of a pin point if you compressed and cooled it, but I still don't think you would have enough to create a blast with a 90 mile radius on earth.
Apr13-08, 07:30 PM   #3
Admin
Quote by Qaiphyx View Post
That doesn't sound right.
One can do a simple calculation based on a hydrogen plasma with the density of water, about 1 g/cm3, which is a little less than the average density. Multiply the density by the volume of a pin point to get the mass, and figure some appropriate temperature.
The sun is based on the pp-chain, and p-p fusion is very slow, say compared to d-d fusion, and that's why the sun has been around for a long time.
Bear in mind that the core of the sun is on the order of 15 million K, and its density if about 150 times that of water. In contrast, the photosphere has a temperature of about 5800 K and a density on the order of 1E-7 of water (at room temp).
Apr14-08, 01:34 AM   #4
I believe this figure results if you assume that the pinpoint (I suppose the head of a pin was meant) will magically stay at 15 million K, even when radiating such an enormous amount of energy.
Thread Closed
Thread Tools
Similar Threads for: I heard that if you took a peice of the sun the size of a pinpoint...
Thread Forum Replies
Particle Size VS Atom Size General Physics 5
how longs a peice of string Introductory Physics Homework 0
anyone heard of this? Introductory Physics Homework 4
The Electron - Size of Magnetic field vs Size of Electric field High Energy, Nuclear, Particle Physics 5
Size of strings compared to size of elementary particles Beyond the Standard Model 13
