Angular Momentum of a system of particles
The total angular momentum of a system of two particles about the z-axis relative to point A at coordinates (0, -17 m) is calculated using the formula Lsystem = L1 + L2. Particle 1, with a mass of 26 kg and a speed of 43 m/s, contributes L1 = -19006 kg·m²/s, while Particle 2, with a mass of 63 kg and a speed of -37 m/s, contributes L2 = 39627 kg·m²/s. The final total angular momentum is Lsystem = 20621 kg·m²/s, indicating a net counterclockwise direction.
  • Understanding of angular momentum concepts
  • Familiarity with vector cross product calculations
  • Knowledge of mass and velocity relationships in physics
  • Ability to apply coordinate geometry in physics problems
  • Study the principles of angular momentum in multi-particle systems
  • Learn about the vector cross product and its applications in physics
  • Explore the effects of different reference points on angular momentum calculations
  • Investigate the conservation of angular momentum in isolated systems
Physics students, educators, and anyone interested in understanding angular momentum calculations in particle systems.
dumdum000333
Two particles move in opposite directions along a straight line. Prticle 1 of mass m1 = 26kg at x1 = 23 m moves with a speed v1 = 43 m/s(to the right), while the particle 2 of mass m2 = 63 kg at x2= -22 m moves with a speed of -37 m/s(to the left).
Given: Counter clockwise is the positive angular diretion.
what is the total angular momentum of the system about the z-axis relative to point A along y-axis if A is at (0,-17m)?
Lsystem=L1+L2
L=rXp
p=mv
the angular momentum about A for particle 1 would be 17X(26)(43) which would be clockwise making a negative L so L1=-19006kgm^2/s
for particle2 it would be 17X(63)(37) counter clockwise spin about A so L2= 39627
L1+L2= 20621, but this does not seem to be correct
the 2 particles are located on the x-axis if that helps at all
18K
  • · Replies 45 ·
