Why Is a Clockwise Moving Charge in a Magnetic Field Negative?
  • Thread starter Thread starter ttiger2k7
    Charge Negative
The discussion revolves around the behavior of a charged particle moving in a magnetic field, specifically addressing why a clockwise-moving charge is considered negative. The context involves the application of the left-hand and right-hand rules in electromagnetism.
  • Participants explore the relationship between the direction of charge movement and the application of the left-hand and right-hand rules. Questions arise regarding the implications of using different rules for positive and negative charges, and the nature of the magnetic field affecting the charge.
The discussion is active, with participants providing insights into the rules applicable to different charges. Some participants express confusion about the application of these rules and seek clarification on the implications of a charge's direction of motion in a magnetic field.
There are mentions of assumptions regarding the nature of the charge and its interaction with the magnetic field, as well as the distinction between stationary and moving charges in the context of magnetic fields.
ttiger2k7
[SOLVED] Why is the charge negative?
A uniform magnetic field is directed into the page. A charge q moves in a clockwise direction in the plane of the page. The charge q is?
Answer: Negative.
Can someone clarify why it is negative? I know it has something to do with the left hand rule, but I'm not sure. Thanks.
Left-hand rule applies for negative charges, right-hand rule applies for positive. Just try it and you'll see it only works the way described with the left hand, i.e negative charge.
the question u framed is wrong... if in an uniform magneticfield a charge{+ve or-ve} is projected into the field it then circulates. A stationary charge never disturbs magnetic field only moving charge is influenced by magnetic field.. according to u the circulation is clockwise or anti clockwise it can be shown by "right hand thumb rule"
for eg current carrying wires only produces magnetic field... stationary charge never produce magnetic field... if any clarifications PM me
Umm... The charge isn't producing the magnetic field in this problem, it's an external magnetic field?
Okay, so basically if I am unable to use my right hand and it only works with the left hand rule, it's always going to be negative?
If the charge is moving in a circular direction, then you know the magnetic force is centripetal and should point towards the center. Take any instant during the charge's clockwise motion and use the right hand rule to determine the direction of the force. Since you know the force is centripetal, you should know its technical direction; negative charges produce a force in the direction opposite of what the right hand rule implies with v x B (or as Nabeshin pointed out, you could simply use your left hand for negative charges).
  • · Replies 16 ·
