Thread Closed
wind velocity
Share Thread Thread Tools
Apr14-08, 09:04 AM   #1
wind velocity
If I know the force that a wind is exerting on an object, is it be possible to determine what velocity the wind is moving at? I also know the air density.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Iron-platinum alloys could be new-generation hard drives
>> Lab sets a new record for creating heralded photons
>> Breakthrough calls time on bootleg booze
Apr14-08, 09:38 AM   #2
Recognitions:
Gold Membership Gold Member
That's pretty much how anemometers work, so it's definitely possible.
I'm afraid that I can't supply any formulae, though.
Apr14-08, 09:48 AM   #3
The aerodynamic force acting on a solid body can be expressed by a general equation:
F = [tex]1/2 \rho V^2 S C[/tex]
Where:
C is a force coefficient (either lift Cl, drag Cd or Cx, or whatever you're looking for)
S is a reference area (either frontal area, wing area for airplanes etc.)
The problem lies in the coefficient C. It depends on some adimensional numbers (Mach number and Reynolds number in most cases) and is usualy measured in a wind tunnel on a scaled model of the object.
If you were able to measure the force acting on the solid body, and if you knew the value of the aerodynamic coefficient C, then you wuld be also able to calculate the velocity from the formula above.
If you only knew the values of C vs. V (through Reynolds number) then it would necessarily be an iterative process, since you would have to estimate an initial V, then you would calculate C for that V, then you would recalculate V with that value of C, and then recalculate C with the new value of V, and so on and so on and so on... till the convergence of the result.
On the other hand, if you had data (from real-scale or wind-tunnel measurements) which relate directly F to V (usually for incompressible flows and near-standard temperatures) then the process is straightforward: measure F --> read V from the F-V curve.
Apr14-08, 05:35 PM   #4
Mentor
wind velocity
In practice, that method is difficult, but what you could do is use a pito-static tube.
Jun7-08, 06:40 PM   #5
Quote by Daiquiri View Post
Can you add units I shall use to calculate force?
I found that Cx for flat wall is 1.5
R
Jun7-08, 06:57 PM   #6
Mentor
C has no units. The other quantities on the right-hand-side of the equation combine to give force units.
As long as you use a consistent set of units for the different quantities, the result will be a force. For example:
[tex]\rho[/tex] in kg/m^3
V in m/s
S in m^2
Resulting units are
(kg / m^3) * (m/s)^2 * m^2
= (kg / m^3) * (m^2 / s^2) * m^2
= (kg / m^3) * m^4 / s^2
= kg * m / s^2
= Newtons
Jun7-08, 06:59 PM   #7
Thank you
Jun7-08, 07:33 PM   #8
Recognitions:
Homework Helper Homework Help
As mentiond the pitot-static tube measures wind velocity, and does so via comparason of the pressure (force per unit area) in 2chambers connected to tubes, one that face into the wind and and one perpendicular to the wind.
Thread Closed
Thread Tools
Similar Threads for: wind velocity
Thread Forum Replies
Actual Wind Velocity Introductory Physics Homework 7
Velocity of Wind Introductory Physics Homework 1
Wind velocity vs drag Introductory Physics Homework 3
Question with wind velocity Introductory Physics Homework 1
