Which Circuit Drains Batteries Faster: Series or Parallel?
  • Context: High School
  • Thread starter Thread starter sandiego234
    Circuitry Electricity
The discussion revolves around the question of whether batteries connected in a series or parallel circuit configuration would drain faster. Participants explore the implications of current and resistance properties in direct current (DC) circuits, particularly in the context of a lab question involving batteries and resistors.
  • Experimental/applied
  • One participant questions the clarity of the original question, suggesting it may be incomplete or related to homework.
  • Another participant clarifies that the question pertains to whether a battery would run out of charge faster in a series or parallel configuration, emphasizing the role of current and resistance.
  • Some participants propose that a parallel circuit will drain batteries faster due to lower resistance, while others argue that the load affects this outcome.
  • It is suggested that if a resistor is used, batteries in series may drain faster depending on the resistor's value, although this scenario may not reflect practical applications.
  • A later reply encourages calculating the current through each battery in both configurations to determine which drains faster, proposing specific values for simplification.
Participants express differing views on the question, with no consensus reached regarding which configuration drains batteries faster. The discussion remains unresolved as various factors, such as load and resistance, are considered.
Participants note that the outcome may depend on specific conditions, such as the type of load used and the values of the components involved. The discussion highlights the complexity of the question and the need for careful consideration of these factors.
sandiego234
if i used batteries instead of a power source which circuit (series or parallel) would drain the batteries faster and why
THank you.
The question doesn't make any sense - it sounds incomplete. Is this homework?
well it's a lab question. I don't think that it's incomplete. It's simply asking whether a battery would run out of juice faster on a series circuit or parallel...something to do with the current and resistance properties of series/parallel Dc circuits
Parallel circuit will drain faster, due to the lower resistance.
I suppose you mean that the batteries are in series or parallel? It's still dependent on what the load is. if you use a resistor, the batteries in series will drain faster for any value of this resistor, but this is hardly a realistic situation.
What is most interesting, is the efficiency, how much power is used for a given result, in light, heat, mechanical power etc. Answering this question in general isn't useful or interesting IMO.
THank you.
Assume the batteries are connected to a resistor, and figure out what the current
through each battery is when the batteries are in series vs. parallel.
The configuration with the higher current in each battery will drain them faster.
p.s. if it helps you to use actual numbers, make the calculation easier by assuming 1V for each battery and a 1 ohm resistor.
  • · Replies 16 ·
  • · Replies 22 ·
  • · Replies 58 ·
