What are the ideals in various rings?
  • Context: Graduate
  • Thread starter Thread starter nocheesie
    Homomorphisms Ring
The discussion revolves around understanding ideals in various rings, particularly focusing on the integers and their extensions, such as Z[7], Z[6], Z[12], Z[36], Q, and Z[i]. Participants are exploring the definitions, properties, and examples of ideals within these mathematical structures.
  • Some participants express difficulty in understanding homomorphisms and ideals due to a lack of clarity on the concept of rings.
  • One participant suggests that sets of multiples (e.g., multiples of 3, 25, or 100) are ideals, as they are closed under addition and multiplication by any element in the ring.
  • Another participant defines an ideal in a ring as a subset such that the product of any element in the ideal with any element in the ring remains in the ideal, providing examples from the integers.
  • Participants discuss the ideals in Z, noting that they include sets like {...,-2,0,2,4,6,...}, {...,-6,-3,0,3,6,...}, and the zero ideal and the whole ring.
  • In the case of Q, it is mentioned that the only ideals are {0} and Q itself, as any ideal containing a non-zero element must also contain 1, thus becoming the whole ring.
  • There is clarification on the notation Z[i], which refers to Gaussian integers, and a participant explains that it consists of complex numbers with integer coefficients.
  • Discussion on Z[7] indicates that it may only have the zero ideal and the whole ring as ideals, due to the properties of prime numbers.
  • Participants propose that Z[6] may have different ideals due to 6 not being prime, with one suggesting the set {0,3} as a potential ideal.
  • One participant emphasizes the importance of experimentation in understanding the properties of ideals in these rings.
  • There is mention of Z being a principal ideal domain and the relevance of fields in relation to ideals.
Participants express various viewpoints on the nature of ideals in different rings, with some agreeing on the properties of ideals in Z and Q, while others propose differing ideas about Z[6] and Z[7]. The discussion remains unresolved regarding the complete characterization of ideals in Z[6] and Z[12].
Participants note that the understanding of ideals may depend on definitions and properties of the rings in question, particularly regarding whether they are fields or principal ideal domains. There is also mention of the need for further exploration of Z[6] and Z[12] to identify their ideals.
nocheesie
I'm having a very tough time understanding homomorphisms and ideals, probably because I'm very fuzzy with the concept of rings. I'm stuck on the following problem:
Find all the ideals in the following rings:
1. Z
2. Z[7] (Z subscript 7, equivalence classes of 7 I'm guessing)
3. Z[6]
4. Z[12]
5. Z[36]
6. Q (set of rationals)
7. Z (this one wasn't written as a subscript, but as brackets, and "i" as the complex number i. what does that mean?)
Can someone help me to understand these better? I'd really really appreciate it.
1. Z
what about all the multiples of 3?
or all the multiples of 25, or 100?
I think the set of multiples of some number is an interesting set
and isn't it an ideal
(all an ideal means is a subset closed under +
and such that multiplying an element by anything doesn't evict it from
from the set)
but multiplying an even number by anything you still get an even number
multiplying a multiple-of-100 by anything you still get a multiple-of-100
these sets must be ideals!
Okay, an ideal I in a ring R is a subset of R so that the product of anything in the ideal with anything in the ring is in the ideal again. For example, the even integers are an ideal in the integers because an even number times any integer is even. Same goes for 3,4,5, etc. Note that R is an ideal of R, and so is {0} because anything times zero is zero.
I'll get you started on a few of the questions:
1. You want to find all sets I so that for any i in I, and r in Z you have ir in I. It shouldn't be too hard to see that these Is are just things like {...,-2,0,2,4,6,...}, {...,-6,-3,0,3,6,...} etc. That is, the ideals in Z are {0},Z,2Z,3Z, etc.
6. There are only two ideals in Q, {0} and Q. To see why, consider any ideal other than {0}. It contains some fraction a/b. But then a/b * b/a must be in the ideal, so 1 is in the ideal. So for any c/d in Q, 1*c/d is in the ideal. That is, the ideal contains all the fractions so the ideal is Q.
7. Okay, this is a notation thing. If you have a ring R, then the ring R[x] is all the polynomials of x with coefficients in R. For example Q[x]
would be all polynomials with rational coefficients.
In this case, Z is all polynomials like 5i^5+10i^2-i+19. But i^2=-1 so if you simplify all the powers of i, all you are left with is complex numbers with integer coefficients. These are called the 'Gaussian' integers.
Hope this helps.
3. Z[6]
suggest you learn to write Z7
to see how anybody at Physicsforums writes something, pretend you are going to quote them and respond------so click on "quote" underneath their post
you will see how they wrote something
then you can just click "back" on your browser and go away without responding if you please----you don't have to go thru with responding if you don't want
in the case of that, if you press "quote" on this post you will see
that Z7 is written
Z[s u b]7[/s u b]
but removing the spaces in s u b
so that it reads sub
yeah Z7 means the integers modulo 7
which you can think of as equivalence classes
or you can think of them as the set {0, 1, 2, 3, 4, 5, 6}
where after ever + and every x
(after every addition or multiplication)
you mod out any multiple of seven
I don't think Z7 has any ideals excpt the zero ideal
and the whole Z7
because just try
suppose you had an ideal with 2 in it, it has to be closed under addition
so 2+2 has to be in the ideal as well!
2, 2+2, 2+2+2, then the next is 2+2+2+2 = 1
but if 1 is in the ideal then everything is
because you can get anything by adding one to itself.
go ahead and try anything in Z7
like 3
if 3 is in then 3+3+3 = 2
is in and if 2 is in then everything is
Several people here (eg Matt Grime for one) can tell you a theorem that covers all these cases, notice that
7 is a prime number
but sometimes understanding can come just by being patient enough to experiment
Z6 might be different! because 6 is not a prime number
it might be interesting to find the ideals in the ring
Z6
or Z12
I want to see what comes of this
later we can look at Z
which I think is what happens when you throw in the imaginary number thesquareroot of -1
throw that in with the integers
Personally I don't think the rational numbers have any nontrivial ideals
they got nothing but the zero ideal {0} and the whole ring itself
they are a "field" meaning for one thing that multiplicative inverses are
included, so any ideal with nonzero q in it also has 1
because you can multiply q by 1/q and it should not evict you from the ideal so that means 1 is in the ideal, and then it is all over because an ideal
with 1 in it is the whole ring!
but Z might be good to look at because it does not have inverses
however first things first
lets get all the ideal of Z6
in the Z6 case
think about the set {0,3}
isnt that closed under addition?
and what happens if you multiply 3 by
anything in Z6?
does it ever evict you from {0,3}?
or is the result of multiplying always still in {0,3}?
you have to check it but I think that set is
an ideal in Z6
and there may be another one which is not just
the zero ideal or the whole Z6 ring
Wow you guys are soooo helpful! Soo much better than my book which really doesn't explain things very well and has very poor examples. I can't thank you guys enough!
Z_7 and Q are fields, I can tell you a theorem about that, but the general one would be that if I is an ideal and I contains an invertible (multiplicative element) then it is the whole ring, that helps the by hand experimentaion in Z_6 say.
Z is a principal ideal domain - you'd better look that up, and perhaps euclidean domain too, they have useful properties and characterisations.
