Kernel "stable under": is my interpretation correct?
The discussion clarifies the interpretation of the term "stable under" in the context of endomorphisms A1, A2, A3, ..., Ar. Specifically, it confirms that if W is the kernel of Ar - λI (where λ is an eigenvalue), then W is indeed stable under the previous endomorphisms A1, A2, ..., Ar-1. This means that for any element u in W, the transformation Aku remains in W, establishing that "stable under" is equivalent to "closed under" in this context.
  • Understanding of endomorphisms in linear algebra
  • Familiarity with eigenvalues and eigenvectors
  • Knowledge of kernel and image concepts in vector spaces
  • Basic comprehension of linear transformations
  • Study the properties of endomorphisms in linear algebra
  • Explore the relationship between kernels and eigenvalues
  • Learn about the implications of stability and closure in vector spaces
  • Investigate examples of linear transformations and their kernels
Mathematicians, students of linear algebra, and anyone studying the properties of linear transformations and their stability in vector spaces.
_Andreas
[SOLVED] Kernel "stable under": is my interpretation correct?
A1, A2, A3,..., Ar are endomorphisms. W is the kernel of Ar - lambda*I, where lambda is the eigenvalue of Ar. W is stable under A1, A2, A3,..., Ar-1. Question: does "stable under" equal "closed under", and is the following interpretation of this stability correct?
For all elements u in W, Aku is an element in W.
I believe so. I can't think what else it would mean.
Ok, thanks!
