Can the Value of e Be Found Using the Taylor Series?
  • Context: Undergrad
  • Thread starter Thread starter johndoe
    Infinity Limit
The discussion revolves around the mathematical constant e, particularly its definitions and how it can be derived or proven using various approaches, including limits and Taylor series. Participants explore different perspectives on defining e and the implications of those definitions.
  • Some participants propose that the limit \(\lim_{x \to \infty} (1 + \frac{1}{x})^x = e\) is a common definition of e.
  • Others argue that without a definition of e, proving its properties is not feasible.
  • A participant discusses using L'Hôpital's Rule to evaluate the limit and derive e from the definition involving derivatives of exponential functions.
  • Another viewpoint presents a definition of e as the base of the natural logarithm, linking it to the integral definition of ln(x).
  • One participant suggests that e can be found using the Taylor Series, specifically through the relationship \(y = e^x\) and its derivative.
Participants express differing definitions and methods for deriving e, indicating that multiple competing views remain. There is no consensus on a single definition or method of proof.
Some discussions depend on specific definitions of e, and the proofs presented rely on assumptions that may not be universally accepted. The exploration of limits and derivatives introduces various mathematical techniques that are not resolved in the conversation.
This discussion may be of interest to students and educators in mathematics, particularly those exploring calculus, limits, and the properties of exponential functions.
johndoe
Why does
[tex]\lim(1+\frac{1}{x})^x = e[/tex]
[tex]x->\infty[/tex]
This is one possible definition of the number e.
What is your definition of e?
O so how do i prove this ?
Let
[tex]L=\lim_{x\rightarrow \infty} (1+\frac{1}{x})^x[/tex]
[tex]ln L =ln \lim_{x\rightarrow \infty} (1+\frac{1}{x})^x[/tex]
[tex]ln L =\lim_{x\rightarrow \infty} xln (1+\frac{1}{x})[/tex]
Then use L'Hopital's Rule twice.
If you don't have a definition of e, then you can't.
How do you prove what?:smile:
yea how do you prove a definition? maybe he means how do you consistency?
Unfortunately, johndoe hasn't gotten back to us to answer the question about what definition of e he is using.
Yes, many texts define e by that limit. If that is the definition, then no "proof" is required.
Others, however, treat the derivative of f(x)= ax this way:
[tex]f(x+ h)= a^{x+ h}= a^x a^h[/tex]
[tex]f(x+ h)- f(x)= a^xa^h- a^x= a^x(a^h- 1)[/tex]
[tex]\frac{f(x+h)- f(x)}{h}= a^x\frac{a^h- 1}{h}[/tex]
Which, after you have shown that
[tex]\lim_{h\rightarrow 0}\frac{a^h-1}{h}[/tex]
exists, shows that the derivative of ax is just a constant times ax.
"e" is then defined as the value of a such that that constant is 1:
[tex]\lim_{h\rightarrow 0}\frac{e^h- 1}{h}= 1[/tex]
We can then argue (roughly, but it can be made rigorous) that if, for h close to 0, (eh-1)/h is close to 1, eh- 1 is close to h and so eh is close to h+ 1. Then, finally, e is close to (h+1)1/h. As h goes to 0, 1/h goes to infinity. letting x= 1/h, (h+1)1/h becomes (1/x+ 1)x so
[tex]\lim_{x\rightarrow \infty}(1+ \frac{1}{x})^x= e[/tex]
Here's a third definition of "e":
It has become more common in Calculus texts to work "the other way". That is, define ln(x) by
[tex]ln(x)= \int_1^x \frac{1}{t}dt[/itex]<br /> From that we can prove all the properties of ln(x) including the fact that it is a "one-to-one" and "onto" function from the set of positive real numbers to the set of all real numbers- and so has an inverse function. Define "exp(x)" to be the inverse function . Then we define "e" to be exp(1) (one can show that exp(x) is, in fact, e to the x power).<br /> <br /> Now, suppose [itex]lim_{x\rightarrow \infty} (1+ 1/x)^x[/itex] equals some number a. Taking the logarithm, x ln(1+ 1/x)must have limit ln(a). Letting y= 1/x, that means that the limit, as y goes to 0, of ln(1+y)/y must be ln(a). But that is of the form "0/0" so we can apply L'hopital's rule: the limit is the same as the limit of 1/(y+1) which is obviously 1. That is, we must have ln(a)= 1 or a= e.[/tex]
[tex] Ok I see. I didn't know that definition before until I reach a problem requiring me to find that limit.[/tex]
I believe that the definition of e is:
e is such that when: y=e^x
dy/dx = e^x
Hence via the Taylor Series, the actual value of e can be found
right?
  • · Replies 19 ·
