| Thread Closed |
Simple Topology Question |
Share Thread |
| Apr18-08, 12:04 AM | #1 |
Hi,
I have a question that I'm not sure about. If f:A->C is continuous and B is a subset of C that is simply connected, is f(^-1)(B) necessarily connected or simply connected for that matter? Since the spaces are not necessarily homeomorphic I cannot consider it a topological invariant. Thanks |
| Apr18-08, 12:12 AM | #2 |
Consider the old canonical mapping from [0,2pi) to the circle S^1 in the complex plane (f(t)=e^it). Then for r small enough, f^-1(B(1,r)) is clearly not connected (and hence not simply connected either) since it consist of a little neighborhoods of 0 and a little neighborhoods of 2pi.
| Apr18-08, 04:58 AM | #3 |
Actually, we can be even simpler than that: let f:R->R be given by f(x)=x^2, and let B={1}. Then f^-1(B)={1,-1}.
| Apr18-08, 04:37 PM | #4 |
Thanks for the help! The last one is a very simple counterexample.
| Apr20-08, 05:34 PM | #5 |
Maybe for a more extreme counterexample re connectedness, consider the case of
IR as a covering space of S^1 . Maybe if you had 1-1 -ness. (tho not in this case, since continuous bijection bet. compact and hausdorff is a homeo., which is sufficient, tho I don't know if it is necessary). For a trivial counterexample re simple-connectedness, consider a constant map defined on an annulus. |
| Apr22-08, 11:55 AM | #6 |
Recognitions:
trivial counterexamples do exist for zero dimensional B, but try higher dimensional B's.
and try it for algebraic maps. i.e. if you map an algebraic variety X to an algebraic variety Y, what does the inverse image of an irreducible curve in Y look like? more specifically, project a surface onto P^2, and ask what the inverse image of a general line looks like? see the fulton - hansen connectedness theorem, and various versions of bertini's thoerem. |
| Apr25-08, 04:21 PM | #7 |
Recognitions:
here is a nice theorem of fulton and collaborators:
if L is a linear subspace of a projective space P, having codimension d, and if X-->P is any morphism from a projective variety X, having image in P of dimension larger than d, then the inverse image in X of L is connected. |
| Thread Closed |
Similar discussions for: Simple Topology Question
| two simple questions in topology. | General Math | 2 | ||
| Simple question in topology (finite vs. infinite) | Calculus & Beyond Homework | 4 | ||
| For help, A simple question about topology | General Math | 12 | ||
| Simple question about topology | General Math | 18 | ||
| Simple Topology question | Calculus & Beyond Homework | 1 | ||
