Determine the speed of the stone
  • Thread starter Thread starter hyen84
    Speed
The discussion focuses on two physics problems involving circular motion and tension in strings. The first problem involves a stone tied to a string (length = 1.27 m) being whirled in both horizontal and vertical circles, with the maximum tension in the vertical case being 15% greater than in the horizontal case. The second problem addresses a cylindrical space station rotating at 33.8 m/s, requiring the radius to be calculated for astronauts to weigh half of their Earth weight. Key equations include the maximum tension formula Tmax = W + (mv02/L) and the normal reaction N = W cos(θ) + (mv2/L).
  • Understanding of circular motion dynamics
  • Knowledge of tension in strings and forces
  • Familiarity with centripetal acceleration concepts
  • Basic grasp of gravitational forces and weight
  • Study the principles of centripetal acceleration in vertical circular motion
  • Learn how to derive and apply the tension formulas in varying conditions
  • Explore the effects of radius on artificial gravity in rotating systems
  • Investigate the relationship between angular velocity and centripetal force
Students studying physics, particularly those focusing on mechanics and circular motion, as well as educators looking for practical examples of tension and forces in rotational systems.
hyen84
Need Help ASAP!
hey can some1 help me with these 2 physics questions..really need it...it's my last homework assigment and i have trouble with this 2...please help it's due tomorrow morning...show what me to do..thankssssssssss
1. A stone is tied to a string (length = 1.27 m) and whirled in a circle at the same constant speed in two different ways. First, the circle is horizontal and the string is nearly parallel to the ground. Next, the circle is vertical. In the vertical case the maximum tension in the string is 15% larger than the tension that exists when the circle is horizontal. Determine the speed of the stone.
2.Suppose the surface (radius = r) of a cylindrical space station is rotating at 33.8 m/s to provide artificial gravity. What must be the value of r for the astronauts to weigh 1/2 of their Earth weight?
1) In the horizontal circular motion case, only the string's tension can provide the required centripetal acceleration.
What forces can provide centripetal acceleration when the circular motion is vertical; in particular, when is the tension of the string at its maximum?
1. Tension is max at the bottom of the vertical surface and is given by
[tex]T_{max} = W +\frac{mv_{0}^2}{L}[/tex]
2. N is Normal Reaction and it varies as
[tex]N = W\ cos\theta + \frac{mv^2}{L}[/tex]
where \theta is the angle of astronaut with the vertical at any instant
Since its normal rxn is varying with theta , so its weight registered is also varying
so u can solve it for [tex]\theta =0[/tex] and N= W/2
  • · Replies 18 ·
  • · Replies 16 ·
