SHM - problem with static friction
The problem involves a child sliding a dinner plate in simple harmonic motion (SHM) on a horizontal surface, with specific parameters including mass, amplitude, speed at a given displacement, and a carrot slice on the plate. The questions focus on determining the period of motion, displacement at a different speed, and the coefficient of static friction at the end of the motion.
  • Participants discuss the relationship between the motion of the carrot and the plate, emphasizing the role of static friction and acceleration. There are attempts to link the forces acting on the carrot slice to the conditions for it not to slip.
Some participants have provided insights into the relationship between static friction and the forces acting on the carrot slice, suggesting a connection to the acceleration of the plate. There is an exploration of the necessary conditions for the carrot to remain in place, but no consensus has been reached on the final calculations or interpretations.
The discussion includes references to the maximum acceleration at the endpoints of the SHM and the implications of the phrase "on the verge of slipping," indicating a focus on the limits of static friction. The original poster expresses uncertainty about linking periodic motion to static friction.
SillySylar
A child with poor table manners is sliding his 243 g dinner plate back and forth in SHM with an amplitude of 0.109 m on a horizontal surface. At a point a distance 6.70×10−2 m away from equilibrium, the speed of the plate is 0.250 m/s.
a) What is the period?
b) What is the displacement when the speed is 0.152 m/s?
c) In the center of the dinner plate is a carrot slice of mass 10.7 g. If the carrot slice is just on the verge of slipping at the end point of the path, what is the coefficient of static friction between the carrot slice and the plate?
A = sqrt(x^2 + (v^2/w^2))
I tried the above equation and solved the period and the displacement questions with no problem. However, I really don't know where to start with the last one. Could someone give me some insight please? This homework is in the chapter of "Periodic motion", I'm not sure how to link it to the static friction =(
thank you all for your help, really appreciate it!
In order for the carrot to not slip it must have the same motion--and thus acceleration--as the plate. But the only horizontal force accelerating the carrot is static friction from the plate. What maximum value of static friction is required? What does that tell you about the minimum coefficient of static friction?
When they say "on the verge of" it means set the force of friction = to the other force acting on it. So in this case, the acceleration of the plate at the end of the path = F/m = the force of friction / m
Note that the acceleration is at a maximum at the end of the path.
Cool?
so basically F = ma => k x N = k m g = m a => k = a / g
I got the correct answer using that expression below. Thanks a ton guys :)
  • · Replies 42 ·
9K
  • · Replies 45 ·
