Photons and electric field vectors
The discussion centers on the relationship between photons, electric field vectors, and the theoretical graviton. When two spin-1 photons align their magnetic field vectors, they form a spin-2 particle, which is hypothesized to be a graviton. The conversation explains that a fermion, with its electric and gravitational field vectors, requires a 720-degree rotation to appear unchanged, due to the interaction between the electric and gravitational fields. The vector notation presented defines the gravity vector as the difference between spacelike and timelike vectors, with implications for understanding spin and gravity.
  • Understanding of quantum mechanics, specifically photon spin
  • Familiarity with vector notation in physics
  • Knowledge of electric and gravitational field interactions
  • Basic concepts of particle physics, including fermions and gravitons
  • Research the properties of spin-2 particles and their implications in quantum field theory
  • Study the role of electric and gravitational fields in particle interactions
  • Learn about the mathematical representation of vector fields in physics
  • Explore the theoretical framework surrounding gravitons and their significance in quantum gravity
Physicists, students of quantum mechanics, and researchers interested in the theoretical aspects of particle physics and gravitation.
kurious
fermion rotates through 720 degrees
If two spin 1 photons are put together so that the tips of their magnetic field vectors just touch one another ( the vector lines are all in the same plane), a particle results which looks the same when it is rotated through 180 degrees - a spin 2 particle.This is the spin a graviton is supposed to have.
Is this a graviton?
If a fermion has a finite number of electric field vectors pointing in all directions from the surface of a sphere, and it also has field vectors for the gravitational field, then the fact that a fermion has to be rotated through 720 degrees to look the same can be explained.As the electric field vectors rotate, the gravitational field vectors rotate through half the angle they do -
because the rotating electric field vectors generate a force which inhibits the rotation of the gravitational field vectors.
If we write these in vector notations, it will seem like the gravity vector is the different of two vectors:
[tex]V^{-}_G = V_s - V_t[/tex]
where [itex]V_s[/itex] is the spacelike vector and [itex]V_t[/itex] is the timelike vector. The spacelike vector is related to the electric vector and the timelike vector is related to the magnetic vector. Now, if the angle between space-vector and time-vector varies from 0 to 360 deg, spin can be defined.
The above vector difference is the usual gravity vector but the antigravity vector can be given by:
[tex]V^{+}_G = V_t - V_s[/tex]
  • · Replies 16 ·
  • · Replies 21 ·
  • · Replies 16 ·
