Solving Conics: Find the x-Intercept
  • Context: High School
  • Thread starter Thread starter emohunter7
    Conics
The discussion revolves around finding the x-intercept of the quadratic equation y = x^2 - 6x + 3. Participants explore different methods for solving the equation, including completing the square and using the quadratic formula, while addressing potential errors in the initial approach.
  • Homework-related
  • One participant attempts to find the x-intercept by completing the square and expresses uncertainty about the correctness of their solution.
  • Another participant clarifies that the x-intercept occurs where y = 0.
  • A different participant suggests directly setting the equation to zero (0 = x^2 - 6x + 3) as an alternative approach.
  • Concerns are raised about the initial participant's method of solving for x after completing the square, with a claim that the square was not completed correctly.
  • After recognizing the mistake, the initial participant questions if the corrected answer is x = 3 + √6.
  • Another participant confirms that both x = 3 + √6 and x = 3 - √6 are valid solutions, noting the existence of two roots for the quadratic equation.
Participants generally agree on the method of finding the x-intercept but have differing opinions on the correctness of the initial approach and the completion of the square. The discussion remains unresolved regarding the initial participant's understanding of their mistake.
There are unresolved issues regarding the completion of the square and the application of the quadratic formula, as well as the potential for confusion in the initial calculations.
emohunter7
Conics! Help Please!
okay i think i have solved this correctly...still a little unsure though...
y=x^2-6x+3----find x intercept
first i used complete the square---- y-3=(x-3)^2
then i solved for x---- 3+(y-3)^(1/2)=x
then i plugged 0 in for y and got 3+(3^(1/2)) and 3-(3^(1/2))
is that correct??
x intercept is where y=0.
yes i know that is why i made the equation equal to x and plugged 0 in for y
why not just 0=x^2-6x+3?
you get the same answer i was just taught to solve for x first...so is my answer right or wrong??
Try applying the quadratic formula to x^2-6x+3=0 and see if you get the same answer. I certainly don't.
Following your work:
if you plug in 0 for y in 3+(y-3)^(1/2)=x you most certainly don't get 3+(3)^(1/2)=x, but 3+(-3)^(1/2)=x, which is not the answer.
The reason is that you didn't complete the square correctly: y=x^2-6x+3 --> y=x^2-6x+3+6-6 --> y=(x-3)^2-6 --> y+6=(x-3)^2
okay i see where i made my mistake..so the correct answer is x=3+(6^(1/2)) right?
well yes and x=3-6^.5 also (remember there are 2 roots for a quadratic)
okay thank you for your help :)
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 18 ·
