Field lines and Coulomb Forces
The discussion revolves around the behavior of electric field lines and Coulomb forces in the context of two charged spherical conductors. Participants explore the implications of superposition, the nature of electric fields, and the application of Coulomb's law in this scenario, with a focus on theoretical and conceptual aspects.
  • One participant questions whether using Coulomb's force is suitable when considering the interaction of two charged conductors, suggesting that the field may not remain unchanged.
  • Another participant proposes using the superposition principle to calculate the forces acting on the charges, indicating that the forces can be added vectorially.
  • A participant argues that since there are only two charges, there should be only one force, questioning what should be added to that force.
  • It is suggested that to measure the force of a charge, another charge is necessary, and a fictional test charge is often used for simplification.
  • Participants discuss the implications of field lines being twisted and whether this affects the proportionality of the electric field to the inverse square of the distance.
  • One participant asserts that the force between two charged spherical conductors follows Coulomb's law, provided the spheres do not overlap.
  • There is a debate about the necessity of a test charge to establish the relationship E ∝ 1/r², with some participants emphasizing that this relationship is derived from the behavior of test charges.
  • Concerns are raised about how to interpret the electric field when multiple charges are present and how to calculate the resultant field at a point.
Participants express differing views on the application of Coulomb's law and the behavior of electric fields in the presence of multiple charges. There is no consensus on whether the field remains unchanged or how to interpret the twisting of field lines.
Some participants highlight the limitations of using test charges and the assumptions involved in applying Coulomb's law, particularly in the context of non-uniform field lines.
Volcano
The field intencity around a little spherical conductor changes with reverse ratio to the square of their distance. Then let us put another little spherical charged conductor in field of first one. The field lines are no more change with the reverse ratio to the square of their distance(they are twisted). Does using the Coulomb force is suitable?
I think no. Do we assume the field unchanged?
As far as I know you can use superposition. Calculate the force of one of the charges first and add it (+) to the force of the other charge.
There are only two charges, so there must be only one force. What will i add to that force?
Let me try to put it differently. If you are somehow 'measuring' the force of a charge, you need to have another charge. A charge doesn't exert a force on thin air ofcourse.
Usually this is done with a fictional test charge with a charge of +1C. (Because this simplifies the force equation).
The force that one charge of q C exerts on this 1C charge is ofcourse:
[tex]F = \frac{1}{4 \pi \epsilon_0} \frac{ |q|}{r^2}[/tex]
If you have two charges, [tex]q_1, q_2[/tex] than the force is the (vector) addition of the two forces:
[tex]\vec{F} = \vec{F_1} + \vec{F_2}[/tex]
If you need an example, try this:
Two equal positive point charges [tex]q_1 = q_2 = 0.2 \mu \text{C}[/tex] are located at x = 0, y = 0.3m and x = 0, y = -0.3m, respectively. What are the magnitude and direction of the total (net) electric force that these charges exert on a third point charge [tex]Q = 4.0 \mu \text{C}[/tex] at x = 0.4m, y = 0 ?Consider the following sketch:
The sketch shows the force (represented in it's x and y components) on Q due to the upper charge [tex]q_1[/tex].
From Coulomb's law the magnitude F of this force is:
[tex]F = \frac{1}{4 \pi \epsilon_0} \frac{|q_1Q|}{r^2} = (9.0 \times 10^9) \frac{(4.0 \times 10^-6)(2.0 \times 10^-6)}{0.5^2} = 0.29 \text{N}[/tex]
(the radius r = 0.5 can be found by using pythagoras theorem)
The components of this force are given by:
[tex](F_{\text{1 on Q}})_x = F_{\text{1 on Q}} \text{cos} \alpha = 0.29 \frac{0.40}{0.50} = 0.23 \text{N}[/tex]
[tex](F_{\text{1 on Q}})_y = -F_{\text{1 on Q}} \text{sin} \alpha = -0.29 \frac{0.30}{0.50} = -0.17 \text{N}[/tex]
The same forces can be calculated for the lower charge [tex]q_2[/tex], however, since the system in question is symmetrical you can see directly that the x-component is identical, while the y-component is the same except in the other direction.
So:
[tex]F_x = 0.23 + 0.23 = 0.46 \text{N}[/tex]
[tex]F_y = -0.17 + 0.17 = 0[/tex]
The total force on Q is in the +x-direction with magnitude 0.46 N.
I hope this helps to answer your question!
It is perfectly correct, and the only way in fact, to use the superposition principle to find the intensity at an arbitrary point given any number of charges or charged bodies, provided you know the intensity due to each charge. Here, since both are spherically symmetric charges, outside the charged bodies their fields are as if each is a point charge. So, to find the intensity at a point, use the vector sum of the individual intensities, as Nick89 has explained.
No, you misunderstood. Add the fields due to each charge to get the resultant field at a point.
Giving the absolute sign and then taking the vector sum is not correct. Leave out the absolute sign on q.
Sorry I should have been more clear there. The [tex]\vec{F_1}[/tex] force does not correspond to the (non-vector) force above. The first formula is the magnitude only, the direction should be obvious because there are only two charges.
(Note the lack of vector arrow above the F in the first equation)
The direction is usually not easy to see directly when you have multiple charges, that's when you use vector addition to find the direction.
Thank you, but I mean a different thing. There are only two charges(little sphere). The force is between them. Let me try one more.
http://i26.tinypic.com/2mwbh37.jpg
http://i27.tinypic.com/35d6ikz.jpg
Above pictures shows the field lines for a spherical charge. As already known, lines go away uniform for the upper link, so we can say [tex]E \propto \frac{1}{{r^2 }}[/tex]. But for second link, it is not uniform as other. Now can we can say [tex]E \propto \frac{1}{{r^2 }}[/tex] also?
As shown above the field twisted and no more changing with reverse ratio to the square of their distance.
Another say, as you may notice, I add circles which surrond charges. Let's choice two different points on circle for first figure. Any one has the same magnitude of electric field. Now let's do the same thing for second(below) figure. Take two different point on second circle(below figure). Are those two magnitude of field the same? I think no.
The force between two charged spherical conductors is given by the Coulomb's law, where the distance between the charges is calculated from the centres of the spheres, as long as they don't overlap or touch each other.
This is true for any spherically symmetric charge distributions, which means that, if there is a spherically symmetric charge distribution within a sphere, then the field outside the sphere is as if the whole charge is concentrated as a point charge at the centre.
How can you say that [tex]E \propto \frac{1}{{r^2 }}[/tex] without using a test charge?
Can you feel the electric field there yourself? Ofcourse you can't.
The only reason you know that [tex]E \propto \frac{1}{{r^2 }}[/tex] is because, if you hold a test charge of 1C at a distance r near the charge you have drawn, than the force the test charge feels is proportional to 1/r².You want to know how this proportionality works when you have 2 charges?
I can't tell you directly, but in the same manner that you can add the forces, you can also add the electric fields at a point. Doing this for multiple points might give you the result you are looking for.
Exactly this.
This is exactly too. I know this is very easy question. And coulomb Law help to calculate the force. When I look at field lines between two charges, asked myself that, how these twisted field lines already do the same thing like the linear lines. Than thought, maybe we assume something when calculate. Honestly very hard thing to explain with another language :redface: by the way here is the best place to learn. Sorry for my weak language but thank you all for help.
  • · Replies 19 ·
  • · Replies 24 ·
  • · Replies 16 ·
  • · Replies 17 ·
  • · Replies 27 ·
  • · Replies 21 ·
