What exactly do the signs <=> and => mean?
  • Context: High School
  • Thread starter Thread starter ehj
    Mean
The discussion revolves around the meanings of the logical symbols "=>" (implies) and "<=>" (if and only if) in mathematical contexts. Participants explore their interpretations, applications, and implications, particularly in relation to specific examples and statements.
  • Some participants clarify that A => B means if A is true, then B is true, while A <=> B means A implies B and B implies A.
  • There is uncertainty regarding the meaning of the statement b=0 => 0=0, with some participants questioning its relevance and others asserting its truth under certain conditions.
  • One participant suggests that the truth of P => Q does not require P to be true, as it only requires that it is impossible for P to be true and Q to be false simultaneously.
  • Another participant raises the concern that statements like 7+7=14 => 0=0 could be seen as meaningless, prompting further discussion on the utility of such implications.
  • Some participants agree that (sin(x))^2 + (cos(x))^2 = 1 <=> 0=0 is a trivially true statement, while others question the appropriateness of using self-evident truths in logical implications.
  • There is a discussion about the circularity of using 0=0 as a premise in logical statements, with some participants expressing skepticism about its usefulness.
Participants express differing views on the implications of the logical statements discussed, with no consensus reached on the appropriateness or utility of certain examples. The discussion remains unresolved regarding the relevance of self-evident truths in logical implications.
Some statements made in the discussion depend on specific interpretations of logical implications, and there are unresolved questions about the definitions and applications of the symbols involved.
ehj
I don't seem to be able to find a clear answer to this question on the internet. My maths teacher today said that (simplified): b=0 => 0=0 where you multiplied with 0 on both sides. I thought that b=0 <=> 0=0 , but can't explain why, and don't know which is correct, because I don't know, exactly, what the signs mean.
A=>B means A implies B: if A is true then B is true;
A<=>B means A implies B and B implies A.
As for your examples, what is b..??
The statement b=0 => 0=0 doesn't make much sense to me; it's true if b actually is zero and false otherwise, but what are you trying to say with this formula?
The same goes for the statement b=0 <=> 0=0.
The statement
P <=> Q
means the same thing as the pair of statements
P => Q
Q => P
You are incorrect; that implication is, in fact, true. The truth of P=>Q does not require P to be true; it only requires that it is impossible for P to be true and Q to be false simultaneously. If you want to assert that both P and Q were true, then you would assert "P and Q".
You're right of course, thanks.
What could me make forget about "ex falso quodlibet".:smile:
Basically, A=>B means if we know that A is true then B is true, also if we know that B is false we can show that A is false. If all we know is that A is false we aren't certain about B, and if all we know is that B is true we aren't certain about A.
A <=> B means they are either both true or both false.
Is it possible to show what you're saying with an example?
For instance (sin(x))^2 + (cos(x))^2 = 1 is true, so can I write
With Q being "0=0", wouldn't that mean that P can be anything you want, a part from a literal assignment of "0=1" or "0 != 0"?
7+7=14 => 0=0
7+7=15 => 0=0
Wouldn't a statement like that be totally meaningless?
k
Since both sides are true and anything=> True, yes, that is a trivially true statement.
7+7=14 => 0=0
7+7=15 => 0=0
k
The statement
0=1 => 0=0​
is, in fact, a true statement about integers. You might not think it a useful statement, but that doesn't change the fact it's a true statement.
The utility becomes more obvious when you generalize: you know that
x = y => 2x = 2y​
is a true statement, right? It's an obvious (and easily proven) statement about integers! So, it must be true if it happens that x=0 and y=1.
That's why it's a "conditional" clause -- i.e. an "if-then" statement. Suppose that we know P=>Q is true. This tells us that, if P happens to be true, then Q must also be true. But if P doesn't happen to be true, it tells us nothing.
Many good points Hurkyl, thank you. I get why it is true.
But, assuming the OP didn't mangle his professors point in the process of posting this, why would he put a self evident truth or axiom (depending on how you look at it) as Q? (0 = 0, or in English; A thing is equal to itself). You cannot use math to prove 0 = 0. Since math requires that a = a in the first place, that would be a circular argument.
So, I don't see the point of putting 0 = 0 in Q.
k
(sin(x))^2 + (cos(x))^2 = 1 <= 0=0
never seen such an elegant proof of (sin(x))^2 + (cos(x))^2 = 1. ;)
  • · Replies 18 ·
16K
