Electrostatics and electric charge and field
The discussion focuses on a charged sphere suspended in a uniform horizontal electric field, with specific parameters: mass m = 4.0x10-3 kg and charge q = -3 µC. The force exerted by the electric field on the sphere is calculated to be FE = 0.02 N, leading to an electric field strength of E = -0.0067 N/C. The analysis also addresses the sphere's acceleration upon release, emphasizing the need to consider both the vertical component of the electric force and gravitational force in the calculations.
  • Understanding of electrostatics, specifically Coulomb's law (F = k[(|q1|q2|)/r²])
  • Knowledge of electric fields and their relationship to force (E = F/qo)
  • Basic trigonometry, particularly the tangent function for angle calculations
  • Newton's laws of motion, particularly in analyzing forces in multiple dimensions
  • Explore the concept of electric field strength and its calculation in various configurations
  • Study the dynamics of charged particles in electric fields, focusing on acceleration and motion
  • Learn about tension in strings and its role in systems involving forces at angles
  • Investigate the implications of releasing charged objects in electric fields and the resulting motion
Students studying physics, particularly those focusing on electrostatics, mechanics, and force analysis. This discussion is beneficial for anyone tackling problems involving charged objects in electric fields.
chiurox
A charged sphere is suspended by a nonconductive string in a uniform horizontal electric field. The electric field exerts a force on the sphere such that its equilibrium position is diplaced at an angle  = 30° relative to the vertical, as shown in the diagram below. The mass of the sphere is m = 4.0x10-3 kg, and the charge on the sphere is q = -3 uC.
a. What is the force on the sphere exerted by the electric charge?
b. What are the magnitude and the direction of the electric field?
c. The sphere is released from the string. What are the magnitude and the direction of the sphere's subsequent acceleration?
F=k[(|q_1|q_2|)/r²]
E=F/q_o
a)
I first tried to find the length of the displacement due to the force:
tan(theta)=F_E / F_mg
tan(30)=F_E / (9.8)(0.004)
F_E = 0.02 N is this correct?
b)
E=F/q_o
E=0.02 / -3
E=-0.0067 N/C correct?
c)I think the force would be the vertical component of the Electric Force (up) minus gravity, and the direction of the acceleration would be down (-). But how do I find the vertical component of the electrical force?
Thanks
If you do a sum of forces in the x and y directions and set them equal to zero you should have two equations (one for each direction) and two unknowns (the electric field strength and the tension in the string). This will give you the answers to both parts a and b.
Think about what happens when the sphere is released, how could you change the value of the tension in the equations to represent this?
  • · Replies 22 ·
