Why Do Electroscope Leaves Separate Wider When a Balloon is Quickly Moved Away?
  • Thread starter Thread starter username
    Electroscope
The discussion centers on the behavior of an electroscope made from a wine bottle when a charged balloon is moved away. Initially, the electroscope leaves separate due to the balloon's proximity, which induces a charge on the bottle's interior. Upon quickly removing the balloon, the leaves separate even further as they attempt to reclaim the charges deposited on the bottle's sides, resulting in a temporary increase in separation. This phenomenon is attributed to the attraction of opposite charges, not a "backwash" effect.
  • Understanding of electrostatics and charge interactions
  • Familiarity with the principles of an electroscope
  • Basic knowledge of induced charge and polarization
  • Experience with experimental physics setups
  • Research the principles of electrostatic induction
  • Explore the mechanics of charge transfer in electroscopes
  • Study the effects of rapid charge removal on electrostatic systems
  • Investigate the role of dielectric materials in charge retention
Students of physics, educators demonstrating electrostatic principles, and hobbyists interested in experimental physics and electrostatics.
username
Ok, this is not really homework so maybe it needs to be moved some where else.
Made a basic electroscope out of a wine bottle a while ago, charged up a balloon brought it close to the end of the scope and the leaves separated as expected, but when I quickly moved the balloon away from the scope the leaves separated 5 times wider for a few seconds then fell back. Why is this, is it due to some sort of sudden charge backwash in the process of depolarisation (is that a term :/) ?
Thx
Not a "backwash" definitely. I think the following is correct:
the leaves were together before the balloon appraoached. The balloon came close and the leaves separated...
at this point, did the leaves come close to, or touch the sides of the bottle?
If they did, then they deposited a charge on the inside surface which then repelled the leaves slightly. THis would "squeeze" the leaves between opposing forces on both sides. When the balloon is taken away, the leaves desire to take back the charges that were deposited on the sides of the bottle (opposites attract, so all separated charges attract). The leaves come close to, or touch, the sides and pick up the charges and now its neutral again.
Voila, thank's that one has been bugging me for ages.
EDIT: I guess if I did not remove the balloon quickly away the charge on the inside of the bottle would then have time to dissipate reducing the effect.
10K
  • · Replies 19 ·
