Why was the Mars lander set spinning before its final rocket stage?
The discussion revolves around the mechanics of a Mars lander and the reasoning behind setting it spinning before its final rocket stage. Participants are exploring concepts related to angular momentum, stability, and trajectory control in the context of space missions.
  • Participants are attempting to understand the necessity of spinning the lander for stability and trajectory precision. Questions are raised about whether spinning is essential and how it relates to angular momentum and inertia.
The conversation is ongoing, with some participants offering insights into the role of spinning for stability and maintaining orientation during rocket firing. Others express uncertainty about the need to stop the spin and the overall mechanics involved.
Participants are discussing the implications of angular velocity and its effects on the lander's behavior during descent. There is mention of specific mechanisms like "despinning" and the use of weights, but details remain unclear and are under exploration.
forty
Before the final rocket stage the Mars lander was set spinning with an angular velocity directed along the engine force vector.
I am completely lost to why they did this. By spinning the lander do they speed it up? Using the right hand rule the angular velocity vector points in the direction of motion (if i interpreted "angular velocity directed along the engine force vector." correctly).
Any help would be greatly appreciated.
Angular velocity vectors point along the axis of rotation. So if you were watching the lander from above, you would see a small rocket engine firing (or pulsing in burst) to set the lander rotating either clockwise or counter-clockwise.
And why is that necessary for them to set the lander on the right trajectory? can't they do that without it spinning?
Think about what happens when you try to change the direction of the angular momentum. If you want a real life example of this, think of a time that you've held a gyroscope in your hands. This should provide you some clues as to what is happening.
Does it help provide 'stability' ? I'm just trying to use the idea of a gyroscope :S
It is for stability and to maintain the spacecraft in a (reasonably) fixed orientation. This is important if the main rocket engine is going to change the velocity of the descending lander in a predictable way.
So from what I've gathered, before the final rockets are fired it is set spinning, to help its stability and maintain a fixed orientation while the last stage rockets are firing. The spinning is then stopped (by some weights being fired out to either side -> increasing moment of inertia, these weights are then detached). Then on its decent it is set spinning for the same reasons as before?
Please tell me I'm on the right direction. Rotations just aren't my thing >_>
I would suppose that is correct. (I'm not clear about why they bother stopping the rotation -- "despinning", as they call it -- if they need to have it spinning again later.)
Well the exact question I'm trying to answer is as follows:
just before the final rocket engine was fired to set the Mars lander on its trajectory to Mars, which required a high-precision velocity force vector, the lander was set spinning with an angular velocity directed along the engine force vector. Describe in words why you think it was necessary for the engine to fire while the lander was spinning. Also describe how the spin was stopped after the engine fired by launching two small weights transverse to the angular velocity vector on the end of long wires which were later jettisoned.I can explain the 2nd part of the question in regards to the despin but as for why it needs to spin for it to have a high-precision velocity vector stumps me. The only real thing i can think of is that it provides stability, or rather an increase in a resistance to change of its velocity kind of like an increase in inertia.
  • · Replies 23 ·
