MOX Fuel Usage in 3rd Gen Reactors: Questions & Comments
  • Thread starter Thread starter vanesch
    Fuel
The discussion centers on the use of MOX (Mixed Oxide) fuel in third-generation reactors, specifically the EPR (European Pressurized Reactor). It is established that EPR reactors can only utilize approximately 50% MOX fuel due to design limitations. A full MOX core would necessitate a significantly higher control rod density, as MOX fuel exhibits increased reactivity at higher burnups. The EPR's core design, which includes 241 assemblies and 89 control rod sets, is compared to other reactor designs like the Siemens KONVOI and French P4/N4.
  • Understanding of MOX fuel properties and behavior
  • Familiarity with EPR reactor design and specifications
  • Knowledge of control rod functionality and density requirements
  • Awareness of reactor core configurations
  • Research the design specifications of the EPR reactor, focusing on control rod configurations
  • Explore the differences in reactivity between MOX fuel and traditional uranium fuel
  • Investigate the System 80 reactor design and its control rod density requirements
  • Examine the licensing process for new reactor designs, particularly for MOX fuel usage
Nuclear engineers, reactor designers, and professionals involved in the development and optimization of advanced nuclear fuel technologies.
vanesch
Staff Emeritus
I have again a question:
In the new 3rd generation reactors, I thought that one could run entirely on MOXed fuel. On the other hand, I read somewhere that an EPR reactor can only be filled for about 50% with MOXed fuel.
Any comments ? And if the second thing is true, is there a fundamental problem in designing a PWR running purely on MOX fuel ?
The core design for EPR is similar in approach to standard Siemens KONVOI and French P4/N4, in terms of the core configuration and control rod density.
The EPR has 241 assemblies with 89 control rod sets of which 37 are used for power shaping and power maneuvering, and 52 are in the shutdown bank. This is 0.37% of the core, and there are 152 assemblies without rods.
See - 23/33 in http://www.areva-np.com/common/liblocal/docs/Brochure/EPR_US_%20May%202005.pdf
To run full MOX core requires more than twice the CR density. For example, the System 80 units by Combusion Engineering (3 Palo Verde units and several modern Korean units) were designed such that nearly all assemblies have control rods.
http://www.nuc.berkeley.edu/designs/sys80/ici.gif (not so great quality)
MOX fuel has more reactivity particularly at higher burnups, so more control rods are needed to maintain shutdown margin.
This might be of interest - http://www.nrc.gov/reactors/new-licensing/design-cert/epr.html
12K
  • · Replies 83 ·
19K
  • Poll Poll
  • · Replies 52 ·
9K
