How is oil extracted from porous reservoirs
  • Thread starter Thread starter bishwa
    Oil
The discussion revolves around the extraction of oil from porous reservoirs, exploring methods of extraction and the role of magnetohydrodynamics in understanding fluid behavior within these systems. The scope includes technical explanations and conceptual clarifications related to fluid mechanics and extraction techniques.
  • Technical explanation, Conceptual clarification, Debate/contested
  • One participant seeks assistance in understanding how oil is extracted from porous reservoirs.
  • Another participant describes two common methods of extraction: water flooding to displace oil and a newer method involving bacteria to enhance oil recovery.
  • A participant questions the involvement of magnetohydrodynamics in the extraction process.
  • It is proposed that magnetohydrodynamics is used to model the physical properties of fluids involved in oil extraction, aiding in predictions about fluid behavior in various scenarios.
Participants express differing views on the methods of oil extraction and the role of magnetohydrodynamics, indicating that multiple competing perspectives remain without a clear consensus.
Some assumptions about the effectiveness of the extraction methods and the specific applications of magnetohydrodynamics are not fully explored, leaving potential gaps in understanding the complete process.
bishwa
http://www.maths.gla.ac.uk/research/groups/fluids-mhd/[/QUOTE]
i can figure how it is done would anyone help me?
There are 2 "most used" ways, that I know of, to extract oil from a porous material. The first way is to pump water below the reservoir and let the oil ride up, this can typically get about 40% of the oil traped in the porous material. Another, newer, method is to use bacteria, basically add a bunch of bacteria, let it sit for a few days and then pump water in again.
The web-page you cited is simply a research group that uses mathematical models to find the relationships between various micro (and macro) structures, and to predict some of the physical properties (permeability, conductivity, etc.) involved in fluid mechanics and magnetohydrodynamics.
what i wanted to know was that is magnetohydrodynamics involved in it?
I believe magnetohydrodynamics is used to model/determine the physical properties of water, oil and oil-water emulsions. So it is involved in the respect that it helps model how the oil/water behaves. In the same way that fluiddynamics is involved in determining how air will flow over an airplane wing. It helps to predict what will happen or work better in certain circumstances.
