How Does Water Pressure Affect Buoyancy in Different Submerged Objects?
This discussion focuses on the relationship between water pressure and buoyancy in submerged objects, specifically air-filled balls and solid objects in a tube at a depth of 10 feet. The pressure exerted on the uppermost ball to displace it from the tube is determined by the water pressure at that depth, which is approximately 4.33 psi (pounds per square inch). The buoyancy force acting on the balls is equal to the weight of the water displaced by them, and this force must be considered when calculating the total force required to push the balls or solid objects deeper into the water.
  • Understanding of buoyancy principles and Archimedes' principle
  • Knowledge of hydrostatic pressure calculations
  • Familiarity with the concept of density and volume displacement
  • Basic physics concepts related to forces and equilibrium
  • Research hydrostatic pressure calculations at various depths in fluids
  • Study Archimedes' principle and its applications in buoyancy
  • Explore the effects of object shape on buoyancy and displacement
  • Learn about fluid dynamics and the behavior of submerged objects
This discussion is beneficial for students studying physics, particularly those focusing on fluid mechanics, as well as educators and anyone interested in understanding the principles of buoyancy and pressure in submerged environments.
alibaba2
hi, I'm stuck on a homework task I've been given..help will be greatly appreciated:))
image link: img168.imageshack.us/my.php?image=image1vn3.jpg
setup is as follows:
image 1 . a tube (1ft diameter) submerged in water. tube is filled with air-filled balls( 1ft diameter) which tightly fit all the way in the tube, leaving only small water pockets in between.
image 2. same tube. solid object , no water gaps.
at 10ft depth, what would be the pressure that will have to be exerted on the uppermost ball in order to push the first ball out of the tube . i can't understand the buoyancy issue...??will it be equal to the sum of the buoyancy forces of all the balls?or will it be the pressure (kg/cm2) at a depth of 10ft. ...bit of a mess:)
what will be the difference if the shape was like that in image2? i want to calculate what would be the force to push the object 1ft deeper into the water outside the tube??
thank you
anybody??
ANybody?
  • · Replies 25 ·
