Two functions having the same areas x to dx
  • Context: Undergrad
  • Thread starter Thread starter dmcoleman
    Areas Dx Functions
The discussion centers on determining a constant A in the linear function f(x) = Ax such that its area under the curve from x=0 to x=2 equals the area under the curve of the quadratic function f(x) = x^2 over the same interval. Participants confirm that the solution involves integrating both functions between the specified limits and setting the resulting areas equal to each other. This process allows for the calculation of the value of A by solving the resulting equation derived from the integrals.
  • Understanding of definite integrals in calculus
  • Familiarity with basic functions, specifically linear and quadratic functions
  • Knowledge of how to set equations equal to each other
  • Ability to solve algebraic equations
  • Learn how to perform definite integrals using calculus techniques
  • Study the properties of linear and quadratic functions
  • Explore applications of integration in determining areas under curves
  • Investigate the concept of area equivalence between different functions
Students and educators in mathematics, particularly those studying calculus, as well as anyone interested in understanding the relationship between different types of functions and their areas under curves.
dmcoleman
Hi I have been thinking about an idea I have involving calculus that I think someone here can help me with. Is there a way you can determine a simple function (like f(x)=Ax) that has the same area dA from X to dX as another complicated function like f(x)=x^2. If you refer to the two attachments to this post you will see two graphs of two functions f(x)=X^2 and f(x)=Ax. The area under the curve of both functions from x=0 to x=2 are equal. My question is how can we determine the value of the variable A in the function f(x)=Ax if these conditions are to be satisfied. Thanks.
Welcome to PF,
Simple: Integrate both functions between the same two limits and set them equal. You should them be able to determine the value of your coefficient. Indefinite integration returns the area bounded by the curve, the limits and [in this case] the x-axis.
1. Calculate each of the integrals, with "A" an as yet undetermined constant.
2. The requirement that these two integrals, i.e areas, gives you an equation you may solve for A.
  • · Replies 31 ·
  • · Replies 36 ·
  • · Replies 25 ·
