Question about conservation of momentum
The discussion revolves around a conservation of momentum problem involving a 10 kg sphere colliding with two 5 kg spheres at different angles. The original poster seeks to determine the initial velocity of the 10 kg sphere based on the post-collision velocities and angles of the smaller spheres.
  • Participants explore the assumptions regarding the nature of the collision (elastic vs. inelastic) and the timing of the collisions. Questions arise about the initial conditions, such as whether the 10 kg sphere is at rest after the collision and how the angles from the normal affect the calculations.
The discussion is ongoing, with participants providing insights and questioning the assumptions made in the problem. Some guidance has been offered, such as the suggestion to draw a diagram to clarify the scenario, but no consensus has been reached on the specifics of the calculations or assumptions.
There is uncertainty regarding the initial state of the 10 kg sphere post-collision and the interpretation of angles described in the problem. The original poster's request for help indicates a need for clarification on these points.
harryWin
Hi everyone,
If you have a sphere of 10kg, traveling at an initial velocity v. And this sphere collides with two other spheres, each of 5kg. One shoots off at an angle of 60 degrees from the normal, and one at 45 degrees from the normal. There sphere that fires off at 60 degrees now travels at 4 m/s. How can I calculate the initial velocity of the 10 kg sphere?
All momentum is conserved.
Cheers
Is the 10 kg sphere at rest finally? I don't think it can't be done without that fact.
did you try to do the problem yourself?
Assuming the collision is elastic, then both momentum and energy are conserved. Before the collision, all of the momentum (mv) and energy (1/2 m v^2) was in the 10 kg sphere.
You also have to assume that the 10kg sphere collided with both the 5kg spheres at the same time. I'm not sure if it works out to be the same if you assume that the collsion with the 45 degree sphere occurred first and then the collsion with the 60 degree sphere second.
Also the problem statement quotes degress from the normal, which if meant literally, means that the 60 degree ball ends up going 30 degrees from the direction that the 10kg ball was going, if "normal" means perpendicular as it usually does.
Harry, draw a picture of the problem. It makes life easter:wink:
18K
  • · Replies 19 ·
  • · Replies 59 ·
