What is the electric field above a square loop carrying a uniform line charge?
The electric field above a square loop carrying a uniform line charge λ can be calculated using symmetry principles and integration. The vertical component of the electric field from one edge is expressed as \(\frac{2}{{4\pi \varepsilon }}\int\limits_{x1 }^{x2 } {\frac{\lambda }{{\left( {x^2 + z^2 } \right)}}} \cos \phi dx\), where \(\cos(\phi) = \frac{z}{\sqrt{x^2+z^2}}\). The limits of integration are defined as \(x1 = \frac{s}{2}\) and \(x2 = \frac{s}{\sqrt{2}}\). The final result is obtained by multiplying the integral by 4 to account for all edges of the square loop.
  • Understanding of electric fields and line charges
  • Familiarity with integration techniques in calculus
  • Knowledge of symmetry in physics
  • Basic understanding of trigonometric functions
  • Study the derivation of electric fields from continuous charge distributions
  • Learn about the application of Gauss's Law in electrostatics
  • Explore advanced integration techniques for physics problems
  • Investigate the effects of different geometries on electric field calculations
Physics students, educators, and anyone interested in electrostatics and electric field calculations, particularly those dealing with charge distributions and integration methods.
Niles
[SOLVED] Electric field of a plate
Find the electric field a distance z above the center of a square loop (side s) carrying a uniform line charge λ (see Figure 1) - it's problem 2 on this page:
http://teacher.pas.rochester.edu/PHY217/Homework/HomeworkSet3/HomeworkSet3.html
Ok, first I use symmetry, so the horizontal components must cancel for the 4 edges. The vertical component of one edge is given by:
[tex]\frac{2}{{4\pi \varepsilon }}\int\limits_{x1 }^{x2 } {\frac{\lambda }{{\left( {x^2 + z^2 } \right)}}} \cos \phi dx[/tex],
where cos(\phi) = z / sqrt(x^2+z^2) so x1 = s/2 and x2=s/sqrt(2) since these are the minimal and maximal values of x.
Pay attention to that I have multiplied with 2, so we find the one whole edge, not just the half of one edge. I integrate, and multiply it all with 4 to give the correct result.
Am I correct?
  • · Replies 16 ·
  • · Replies 22 ·
  • · Replies 73 ·
