Atmospheric Scattering Problem
  • Context: Graduate
  • Thread starter Thread starter jcdenton89
The discussion centers on the atmospheric scattering of light, specifically how the Earth's atmosphere would appear if it scattered green light instead of blue light. The user concludes that under this scenario, the sun would likely appear magenta due to the scattering effects of Rayleigh scattering. This is based on the understanding that with green light being scattered, the remaining light would consist primarily of blue and red wavelengths, which combine to create a magenta hue. The user references the 'green flash' phenomenon as a related concept.
  • Understanding of Rayleigh scattering principles
  • Knowledge of additive color mixing
  • Familiarity with light wavelength and frequency concepts
  • Basic awareness of atmospheric optics
  • Research Rayleigh scattering and its effects on light color perception
  • Study the principles of additive color mixing in detail
  • Explore atmospheric optics and phenomena like the 'green flash'
  • Investigate the impact of different atmospheric compositions on light scattering
Physicists, atmospheric scientists, educators in optics, and anyone interested in the visual effects of light scattering in the atmosphere.
jcdenton89
Hello,
So I have a scenario where the Earth's atmosphere, instead of scattering blue light from the sun, actually scatters green light based on Rayleigh scattering.
I know that the sky will therefore appear green, but how will the sun appear?
I reasoned the sun will be magenta using the normal situation on Earth.
The sun appears yellow/red (toward sunsets) even though its true color is closer to white because the sun's high frequency light (violet/blue) is scattered in the atmosphere by oxygen and nitrogen molecules. Yellows and reds are low frequency, long wavelength, and are able to penetrate the atmosphere without scattering. During sunsets, the angle of sunlight is very shallow and must go through more atmosphere and undergo more scattering. Much less blue light is transmitted and the low end of the color spectrum is dominant.
If in a similar situation, green light were to be scattered, then wouldn't green light be much less dominant in the color spectrum? So by removing Green from the additive primary colors, we lose yellow (normal perceived sun color) and cyan as well. The blue and red frequency light will be able to penetrate the atmosphere, mix, and result in magenta with a scattered green sky as the background.
What do you think? I was toying between a yellow or magenta sun...but i think magenta seems a good option.
Science news on Phys.org
  • · Replies 40 ·
9K
12K
