Calculating work done by a force field using Green's Theorem on a triangle
The problem involves using Green's Theorem to calculate the work done by a specified force field in moving a particle around a triangular path defined by three vertices. The force field is given as F = <5x²y³, 7x³y²>.
  • Participants discuss the setup of the integral needed to apply Green's Theorem, with one participant attempting to integrate 6x²y² over the triangle. There are questions about the limits of integration and the correctness of the function being integrated.
Some participants confirm the setup is correct, while others suggest re-evaluating the integral limits and the function used. There is an ongoing exploration of the calculations and interpretations of the triangle's boundaries.
One participant notes that the line y=2x is not a side of the triangle, indicating a potential misunderstanding of the triangle's geometry. This highlights the importance of accurately defining the region of integration.
kasse
Use Green's Theorem to calculate the work done by the force field
F = <5x2y3, 7x3y2>
in moving a particle counterclockwise once around the triangle with vertices (0, 0), (3, 0) and 0, 6).
2. The attempt at a solution
I must integrate 6x2y2 over the triangle, right? I then get 1944 as the answer, but the correct answer is 972/5. What is wrong?
Yep, you got it set up all right. But I do get 972/5 for the double integral of 6*x^2*y^2 over the triangle. Check that again. Post how you worked it out if you can't get it.
OK, i integrate with respect to y first, which gives 2x^2*y^3. The limits are y=0 and y=2x, so I now have to integrate 16x^5 with respect to x. This gives (8/3)x^6, and the limits are x=0 and x=3, so that the answer is 1944.
y=2x isn't one of the sides of your triangle. y=6-2x is. Draw a picture.
Lol, thanks!
