Source for t and pi networks in control systems
There is a request for reading material on T and PI network compensation in control systems. The discussion highlights the connection between these networks and their use as notch or bandpass filters. A question is raised about the application of notch filters in feedback systems, indicating a curiosity about their practical benefits. Participants are encouraged to share knowledge or resources related to this topic. The conversation seeks to deepen understanding of T and PI networks in control systems.
maverick280857
Hi
I couldn't find any specific reading material for T and PI network based compensation in control systems. I was hoping someone could point me in the right direction. If you happen to know something about this, please do reply to this thread.
Thanks in advance.
I don't know much on this, but these are usually notch or bandpass filters. So abstractly (ignore circuit topology), how would a notch filter help you in a feedback system? I ask this not knowing the answer, I'm just curious what your application would be.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
