Get Help with Homework - Fr, Power, Speed & More
The discussion revolves around a physics homework problem related to work, power, and forces acting on a car. The original poster is tasked with defining work and power, deriving a relationship between power and tractive force, and calculating resistive force and maximum speed under specific conditions.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to relate definitions of work and power to the problem but expresses uncertainty about the term "tractive force." Some participants provide definitions and suggest including units in the response. Others question the original poster's understanding of forces acting on the vehicle and the implications of maximum velocity on net force.
Participants are actively engaging with the problem, providing hints and clarifications. There is a mix of interpretations regarding the calculations and definitions, with some guidance offered on approaching the resistive force and the relationship between forces. The conversation reflects ongoing exploration without a clear consensus on the final answers.
The original poster mentions difficulties in finding definitions and relationships, indicating a potential gap in understanding the terminology and concepts involved in the problem. There are also references to homework constraints, such as the requirement to show all working.
farso
Hi everyone, just found this place and think its a brill idea that people can get extra help outside of class! Hope one or two of you can assist me with my problem!
Thanks!
3) (a) Define the terms Work and Power. Derive an equation relating the power developed by an engine and the tractive force it produces. Note: ‘derive’ means show all working! [4]
The resistance to the motion of a car, Fr, of mass 2000 kg is proportional to its speed (i.e. Fr=kV). With the engine working at 72 kW the car can attain a maximum speed of 12 m/s when traveling up a straight hill inclined at and angle  to the horizontal when sin = 0.1.
(b) Calculate the value of the resistive force and show that the value of k is
333.3 Ns/m. [6]
(c) Find the greatest speed at which the car could travel down the road with the engine working at 72 kW.
work=force*distance
power=work/time
Ive had a good look at this, and the only relationship that i am able to come up with in relation to both the work and power definitions is basically just
power=(force*distance)/time
I know that this statement is correct, but i just don't think that it is the correct answer for the question. And it seems that without this its not very easy to progess onto the next parts of the question.
Being quite honest, I am not entirely sure what tractive force actually is, I've had a good look around google and not come up with much, and especially nothing in the way of a definition.
So basically I am stumped
Hope you can help
Thanks!
a tractive force is an antiquated term for force pulling something, specifically regarding a locomotive (or an engine in general in this problem).
The mathematical definitions of work and power are the equations that you gave (a more elegant definition of work might be 'change in energy' (Ef - Ei) ); perhaps they're looking for a verbal definition?
Welcome to PF!
Hi farso! Welcome to PF! :smile:
Yes … as lzkelley says, "tractive" just means pulling … they use it a lot on Star Trek!
Your equation for power seems fine, except that they ask you to "show all working" … and what working is there in a definnition?
I think perhaps they want you to put the units in, to show that you know whether it's Newtons or millie Newtons or whatever. :confused:
Are you ok now on (b) and (c)? :smile:
Thats great thank you! I'll include units and also a verbal definition of what I've shown to make it clear.
Quite honestly, I am having trouble finding a way of working out resistive force, seems like the term isn't used very widely?
Naturally i know that F=mg, but I can't make the link between that and Fr=kV or the equation i previously wrote.
Thanks again for your helps!
when the car/train/thing reaches its maximum velocity - what happens to its acceleration? What does that tell you about the net force? what does that tell you about the individual forces?
I assumed instant acceleration to max velocity, and i know that they are all in equilibrium, I am just having real difficulties proving that coefficient f is 333.33... Have you got any hints on how this might be proved?
Thanks
farso said:
I assumed instant acceleration to max velocity…
Hi farso! :smile:
How it got there (the acceleration) doesn't matter …
Anyway, show us what figure you got, and how you got it! :smile:
Ok then, work so far...
a) work = force*distance
power = work/time
therefore power=(force*displacement)/time
as displacement/time = velocity
power = force*velocity
tractive force = power/velocity
b)
Ive tried calculating each force acting upon the vehicle if the surface was frictionless.
mg=19620J
theta = 5.74deg
in its components,
wx=mg sin(theta) = 1962.28J
wy=-mg cos(theta) = -19521.63
tractive force= 6000(not sure on units)
I also know the resistive force is supposed to equal the tractive force while it is not accelerating, and the power remains constant.
Im certainly missing something, but it feels like I've tried everything.
Hi farso! :smile:
Yes … you're missing an equation! :wink:
Both the resistive and the tractive force are along the slope, so calculate the forces along the slope.
That'll be tractive force = resistive force + component of weight.
Which is … ? :smile:
Ok, I think i may have got this now thanks to tiny tim!
Tractive force id calculated to 6000 using tf=p/v
the resistive force was calculated to nearly 4000 using fr=kV
and the weight of the vehicle is naturally 2000kg
Therefore using your equation, this proves k to be 333.3
Please tell me I am correct on this... I could nearly cry over this assingment ;)
Hi farso! :smile:
Yes, you've certainly got the right result :smile: … but I think you've fiddled it … :rolleyes:
You haven't converted the kg into N, and you haven't used the slope.
(btw, what letter did you use for the angle? it came out as a square on my computer)
Try again! :smile:
Sorry, i copied and pasted and it was theta before that.
Still can't get this working right, I am using wx=mg sin(theta) to get component force but it still falls short. I am really sorry if you think I am being slightly dumb here, I just don't get this problem at all and its always the way that anything that I don't understand tends to come up in the exams!
Hi farso! :smile:
(Copy this θ in future … it's unicode, so it should show up fine on any computer … I got it from http://www.barzilai.org/math_sym.htm. :smile: )
If you used mg sinθ, you should have got 2000*9.81*0.1, which gets you back to about 2000, which is ok. :smile:
Ah, there's my problem! I did asin(0.1) to try and actually figure out the angle which θ related to. Thanks very much for all your help!
  • · Replies 20 ·
  • · Replies 26 ·
