| Thread Closed |
Engine Pressure |
Share Thread | Thread Tools |
| Apr28-08, 03:23 AM | #1 |
Engine Pressure
Hello,
I was wondering if anyone could tell me or show me how to calculate the pressure inside the cumbustion chamber of a Briggs and Stratton 5hp engine. This calculation is done at 3800 rpm. Thanks Ditch |
| Apr28-08, 03:28 PM | #2 |
This is a complex question, and the pressure doesn't stay constant at any point during the combustion cycle.
Mean Effective Pressure is calculated by: MEP = 1000 * (P * Nr) / (V * N) Where MEP is in kPa, P is power in kW, Nr is the number of crank revolutions per power stroke, V the displaced volume per cylinder, and N the number of cylinders. Note that the peak cylinder pressure will be much higher than this, but the calculation of this is far more involved. |
| Apr28-08, 07:59 PM | #3 |
Thanks a lot this will really help with what we are doing
Ditch |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Engine Pressure
| pressure, temperatur inside ic engine...... | Mechanical Engineering | 11 | ||
| pressure inside an ic engine | Mechanical Engineering | 17 | ||
| Engine experts, how does rod ratio effect how much pressure is applied to cyl. walls? | Mechanical Engineering | 20 | ||
| Engine cylinder pressure | Mechanical Engineering | 15 | ||
