Minimum Proton Energy for Producing Antiprotons
  • Thread starter Thread starter ehrenfest
The discussion revolves around determining the minimum energy required for protons in an accelerator to produce antiprotons through a specific reaction involving protons and antiprotons. The subject area includes concepts from particle physics and relativistic energy-momentum relations.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the conservation of four-momentum and energy in the context of the reaction. There are discussions about the implications of different reference frames, particularly the center of mass frame, and how they affect the calculations. Some participants question the assumptions regarding the initial conditions of the protons and the implications for energy calculations.
The discussion is active, with participants providing various insights into the conservation laws relevant to the problem. Some guidance has been offered regarding the use of four-momentum vectors and the significance of reference frames, but there is no explicit consensus on the approach to take or the specific calculations needed.
Participants note the importance of specifying the frame in which energy calculations are made, as well as the need to consider relativistic effects when dealing with kinetic and rest mass energies. There is also mention of the potential confusion surrounding the definitions of the center of mass and center of momentum frames.
ehrenfest
What is the minimum proton energy needed in an accelerator to produce antiprotons [itex]\bar{p}[/itex] by the reaction
[tex]p+p \to p+p + (p+\bar{p})[/tex]
The mass of a proton and antiproton is m_p.
I said 2 m_p c^2 because that is the sum of the rest energies of a proton and an antiproton. Apparently that is wrong.
The velocities of the reaction products can't all be 0. Use conservation of momentum.
Hmm. So, the momentum four-vector of the system has to conserved, right? Is it true that the total energy of the system has to be conserved, right? I was always confused about that.
The total energy is relativistic kinetic energy + rest energy =[tex]\frac{1}{\sqrt{1-\frac{u^2}{c^2}}}mc^2[/tex].
OK. I see now. The four-momentum contains the total energy as one of its components. And if the four-momentum is conserved then all of its components are conserved. But please confirm that four-momentum is conserved here.
I am not really sure how to implement that though. I will probably need
[tex]E^2 = p^2 c^2 +m^2 c^4[/tex]
What is the first thing I should do?
I think you may try to use four-momentum vector approach.
This will never wrong~
and i think the answer is something like [tex]7m_p c^2[/tex]
Four momentum is always conserved. You can make the calculation much easier by noting that the square of the energy-momentum four-vector is Lorentz invariant (i.e. doesn't change with a Lorentz boost).
Does one assume that the two initial protons collide head on? That would produce the minimal energy. If one proton is at rest then there is recoil to consider.
Also, when a particles kinetic energy is equal to rest mass, then one must consider relativistic effects. Total energy and momentum are conserved.
That would be the case if one of the protons were stationary, but that isn't the most efficient method of creating a particle-anti-particle pair :wink:
Note also that your value contains the rest mass of the proton.
Edit: It seems Astro beat me to it :smile:
OK good so four-momentum is conserved. I am still trying to figure out what the first thing I should do is! So, if we label the six particles in the order from left to right that they appear in the reaction we get
[tex]\sum_{i=1}^2 \mathbf{p}_i - \sum_{i=3}^6 \mathbf{p}_i = 0[/tex]
by conservation of four-momentum. What should I do with that? That is 4 equations containing 24 different quantities. How do I deal with that?
There is no way to answer the question before you say in what frame you want the energy to be calculated! If the reaction is in the center of mass frame, then the energy of each colliding proton must be 2 mc^2 but you said that was wrong?
The back of my book says the answer is
7m_p c^2, including the rest mass of the proton (kinetic energy is 6 m_p c^2)
Honestly, I cannot tell you what frame I want the energy calculated. I posted the question in its entirety! Can you tell me what frame to calculate the energy now that I gave you the answer?
1.The center of mass coordinate system will give the easiest approach to the problem--why?
2.Simply apply the appropriate conservation rules -- how many?-- to relate before and after -- everything will work out just fine. (Think about vectors, four vectors, and/or components thereof, and which might be simplest descriptive tool available to you.
Good luck,
Reilly Atkinson
(This is a very standard problem; an important one as well.)
ehrenfest said:
The back of my book says the answer is .
What they are doing is considering a frame in which one proton is smashing against a second proton initially at rest.
Call P_1 the four-momentum of the moving proton, p_2, the four-momentum of the proton at rest.
Call P_3,P_4,P_5, P_6 the four-momenta of the produced particles. The minimum energy corresponds to the case when they have all the same four-momentum.
we have [tex]P_1 = (E_1, \vec{p_1}), P_2 = (m_p c^2, \vec{0}), P_3=P_4=P_5=P_6 = (E', \vec{p'})[/tex]
Conservation of four-momentum gives
[tex]P_1 + P_2 = 4 P'[/tex]
squaring, you get
[tex]P_1^2 +P_2^2 + 2 P_1 \cdot P_2 = 16 P'^2[/tex]
all the squares give P^2 = m_p^2 c^4.
Finish the calculation and isolate E_1.
Patrick
OK. So we go to the CM coordinate system. In that system the 3-momentum is 0 before the collision, so it has to be zero after the collision. The energy in that system before the collision is given by [tex]E^2 = p_1^2+p_2^2 + 2m_p c^2[/tex]
where p_1 and p_2 are the relativistic momentum of protons 1 and 2.
E^2 must also be conserved.
Is that right?
EDIT: I didn't read the post above when I wrote this.
Do you know that because you have done the problem before or because that is obvious or what? To prove that statement, should I first assume that the four-momenta are different and then use Lagrange multipliers or calculus or something?
What do you mean by this? Should that be P'?
I know that because in the center of mass frame, it's obvious that the minimum energy corresponds to all the particles in th efinal state being at rest. If you boost to the lab frame, they all have the same four-momentum
I meant that for *any* of the P you get that. So that P could be P' or P_1 or P_2 , etc.
That problem is generally given for the target proton at rest, which agrees with the answer in the book. Use the invariance of E^2-p^2, so (4m)^2=(E_lab + m)^2-(p_lab)^2.
Solve for E_lab.
See if i have done anything wrong or not~
First do it in the frame where the target proton (marked 2 below) is stationary.
[tex]P_1 = (E_1/c,p_1,0,0) \mbox{ ; } P_2 = (mc,0,0,0)[/tex]
By conservation of four-momentum,
[tex]P_1 + P_2 = P_3 + P_4 +P_5 +P_6[/tex]
[tex](P_1 + P_2)^2 = (P_3 + P_4 +P_5 +P_6)^2[/tex]
[tex](P_1 + P_2)^2 = P_1^2 + 2P_1 \cdot P_2 + P_2^2 = -2m^2c^2 -2mE_1[/tex]
[tex](P_3 + P_4 +P_5 +P_6)^2 = -4m^2c^2[/tex] (evaluate in CM frame for minimum energy)
Then,
[tex]-2m^2 c^2 -2mE_1 = -16 m^2c^2[/tex]
[tex]E_1 = 7mc^2[/tex]
OK. I understand everything except how you proved that the 4-momenta of the four products of the reaction should be the same to obtain the minimum energy E_1.
So nrqed and tnho say they go to the center-of-mass frame to do this. What do we know about the center-of-mass frame in special relativity? In the nonrelativistic case, we know that the sum of the linear momenta of the particles is 0 in the center-of-mass frame. In special relativity, is it true that the sum of the relativistic momenta is 0 in the center-of-mass frame?
My book talks about the "center-of-momentum" frame although I am not really sure what that means. Is that the same as the center-of-mass frame here?
Yes. I think so. The sum of linear momentum of the particles is zero in the centre of mass frame in SR.
For relatively simple scattering problems, elastic scattering for example, the lab frame - target at rest -- works nicely, and is the standard frame used in most particle physics.
However, for more complex situations involving particle production, the Center of Mass/Momentum frame is preferred, because of the simplicity it affords. (In practice, the Center of Mass and Center of Momentum mean the same thing, here the frame in which the two protons have equal and opposite momentum.) But, to get back to the lab frame requires a Lorentz transformation.
A hint for simplification: let the initial protons move along the z axis - can this be true in both the lab and CM frames?
With this approach, the answer given by nqrd should be very apparent.
Regards,
Reilly Atkinson
13K
9K
  • · Replies 17 ·
